My F-33 seems similar but with one or 2 thru hulls through the cored area but in fiberglass tubes to protect the core.
Alan
Sent: Wednesday, July 20, 2005 1:29 PM
Subject: RE: [freedomyachts2003] Re: General ? F-35 Construction
I don’t know specifically about the 35, but on the 30, the hull is cored to the turn of the bilge or thereabouts. The keel is attached to solid glass, and through hulls go through solid glass as well.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Diane & BobSent: Wednesday, July 20, 2005 10:36 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: General ? F-35 Construction— In freedomyachts2003@yahoogroups.com, reed <rwedler@y…> wrote:> D&B,> What are the answers to your hull core questions? I too would> like to know.> Thanks, Reed> From what we read, hull is all balsa core. There’s a lot of info at http://www.objectarchitects.nl/freedomboard/index.jsp, which is the location of the old Freedom message boards that someone here took the time to cleanup. I also did a “google” search and came up with several articles that discuss the hull construction.Diane & Bob
