Dennis,
If this is a heavy (about 6ga.) heavy stranded, green wire, which I am guessing it is, It is part of the factory installed boding system. Your guess about the stuffing box is correct. What was common practice in the past ,was to clamp this wire with a srtainlees steel hose clamp to the stuffing box. Either the clamp rusted way or it was removed or the wire just pulled out from it and it may still be there. I personally feel that this is not a very good way to doing this as for bonding system to function correctly , one thing(amongst a host of other requirements) is that the connections need to be very sound and just slipping a wire under a hose clamp just doesn’t quite do it. Corrosion , dirt, salt,all to easily defeat this connection. You also got three different metals all tied together at one point in what is generally a very damp(if not wet)salty environment, perfect for galvanic corrosion. Another common way connections were done here( the idea is tying the bonding system to the shaft and prop all of which is in contact with the seawater) Is/was to use a couple of brushes (like electric motor brushes)in contact with the prop shaft. with very often the wire connected to the brushes via the hose clamp method. This approach also fails to work properly in my opinion, again, the connections not being what is needed , particularly the brushes contact on the shaft.
If you want to connect to the stuffung box the wire tneeds to be bolted or screwed with a proper ring terminal with a machine screw tapped /threaded into the stuffing bbox. ALl matting surfaces need to be clean ,bright and shiny. This is one area where the wire connection would benefit from being soldered or braised.
Also, keep in mind if you have somthing like a “DriveSaver” coupled between the gear box coupling and the propshaft a jumper wire is needed to make a connection between the engine bond andthe shaft. The wire to the stffing box woulkd not accomplish this as it is isolated/insulated fromthe shaft by the packing.
To put this altogether, and try to clarify what I am trying to say is. You need one green bonding wire properly connected to the stuffing box(in order to include this in the bonding system) and one green bonding wire to the engine with a jumper across the coupling if a drivesaver or such is fitted, in order to tie the bonding system to the engine and propshaft. Shaft brushes may also be installed.
There is much debate on whether bonding all underwater fittings and other large metal objectsie: fuel, water, tanks, engine, thruhulls, etc) is neccesary or even beneficial. After much research, and discussion, I have tended to favor the practice to un bond and just isolate the fittings.
This is a very complex subject. The amount and placement of zincs , which are a crucial part of this system, is almost an art. Placeing one large zinc and tying everything on the boat to it ,which is what this bonding basically does, is maybe ok in theory, not so much in practice IMHO. I prefer to islolate the thruhulls and individually zinc items that need protection. Further, many of these bonding systems, and that installed on my Freedom and others tries to incorporate a lightning protection system into it. The masts are tied via the same green bonding wireto the bonding system and also this is all then connected to a keel bolt. I prefer a dedicated lighting protection system ,including a tall spike or air terminal(lightning rod) on the tallest mast head, connected by heavy gauge (4 ga) downwire on wood or carbon fiber masts(aluminum masts can be used as there own downwire). This wire can then be connected by 6 ga. feeders to a dedicated ground plate( a long thin -1" x 12’ better than a square 1’x1’ plate) of bronze,copper or monel. Large items like the metal tanks, and engine to be connected by 6ga feeders to this. THe important thing is that the connections be good. The best way I belive is by using heavy tin plated copper split shank bolts. Boats with shrouds and chainplates would also tie these into the ground plate.
On most of the Freedoms ( and many,many others) the bonding wires ore tied togther at various places with a type of terminal block which all to often has wet, dirty,salty,and porly maintained connections. Again, for the system to work properly, ALl the connections need to be clean, shiny, and sound. The system really does need regular maintinence .
As for your prop zinc, If the rate of consumption has jumped I would suspect some stray current corrosion. Check for any hot wires in the bilge , any wires or their connectors in a damp, wet ,salty bilge, or just bundled toghether, can cause stray current to leak and this wil result in zincs dissappearing quickly. Bilge pump ,connections, especially at the submersible float switch are notorious for stray current leakage. There should not be any wire running through or lyingin the bilge. also electric wireing on the engine needs to be clean and well insulated. The prop zinc may just not be large enough, perhaps the prop was changed from a two blade fixed to a larger 3 blade feathering for example. The fact that it is being consumed at least shows that it is working. Worse would be a zinc that lasts forever or more than a season. The zinc should be fairly well eaten up by the end of the season if not, check that it is proper installed ie: making a good connection to the shaft. Perhaps in your case a zinc on the shaft and a zinc on the prop( for instance a prop nut zinc) is needed if you have just one or the other.
For a good discussion of these issues I suggest Nigel Calder’s “Boat Owners Mechanical and Electrical Manual” which I believe should be a part of any sailors booklocker. ALSO Charlie Wing’s “Boatowners Illustrated Electrical Handbook” presents a lot of good information on this and other electrical Issues, practices, and projects.
Sorry this got so long and winding, I did not mean to go on and on ,but I hope this at least helps to answer your question and if not at least steers you in the right direction.
regards,Rick
