Posted by msheehan1 (msheehan1@…>)
I just replaced my Y value and a few things are bothering me. When I
pump I get back pressure that bubbles back into the head. I also get
oder smell in the cockpit.
Any ideas?
Thanks.
Mike
Any ideas?
Thanks.
Mike
Mike,
were you getting any of these symptoms before you replaced the Y-
valve? Is it possible that your vent tube is clogged?
Otherwise, is it possible that you have the Y in the wrong position? I
was once (almost disastrously) quite wrong about the direction a Whale
pump handle was supposed to point, and the thru-hull wasn’t open,
and… well, we’ll leave it at that.
I’ve gotten back-bubbles into the head, but usually when going
overboard, up over the anti-siphon loop, and back down to the thru-
hull. Are all your hose clamps tight?
— In freedomyachts2003@yahoogroups.com, “msheehan1” <msheehan1@y…>
I
get
oder smell in the cockpit.Any ideas?
Thanks.
Mike
Replace the joker valve in the head, Check and tighten the clamps on ALL the plumbing.
PWMmsheehan1 <msheehan1@…> wrote:
I just replaced my Y value and a few things are bothering me. When I pump I get back pressure that bubbles back into the head. I also get oder smell in the cockpit.Any ideas?Thanks.Mike__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Lance,
Thanks for the info, I will check all everything this weekend.
Mike
<lance_ryley@y…> wrote:
Mike,
valve? Is it possible that your vent tube is clogged?Otherwise, is it possible that you have the Y in the wrong
position? I
Whale
and… well, we’ll leave it at that.I’ve gotten back-bubbles into the head, but usually when going
hull. Are all your hose clamps tight?— In freedomyachts2003@yahoogroups.com, “msheehan1”
<msheehan1@y…>
wrote:I just replaced my Y value and a few things are bothering me.
When
I
also
get
Thanks.
Mike
