Posted by Jim Demerest (jdemer@…>)
On my F1988 F36/38 we cut the old panels in half and had additional teak battens made. Cleaned the panels and put up new foam backed vinyl. We like the looks with the additional battens. It also made removing the panel from the boat a "lot’ easier.
Jim Demerest
F36/38 Lady of Remes
Posted by William Bryant (wcbryantjr@…>)
Sent: Wednesday, May 21, 2008 7:56 PM
Subject: [FreedomOwnersGroup] Headliner
Jim Demerest
Posted by Al Lorman (ajl@…>)
Using
foam backed vinyl practically guarantees that the foam will fail at some point,
if not for you then for the next owner. Had I kept Ab Initio longer, I
would have replaced the headliner with something solid, like plastic or Formica.
Al
Lorman
Behalf Of Jim Demerest
Sent: Wednesday, May 21, 2008 7:57 PM
Jim Demerest
Posted by douglas.domurat (douglas.domurat@…>)
Hi,
Ironically I did carry on with Ab Initio (now “Simply Different”)
and replaced the ceiling panels as Al recommended. I agree that
doing away with the fiberglass/foam/vinyl was a good idea. I had a
white platic panel cut to fit the old panels. The plastic was then
grooved and routed to look like wooden planks. For further effect
the panels were then painted off-white to give it some texture and
the teak trim covering the seams re-varnished in a satin finish. The
end result is truly stunning. I also used white formica on the sides
surrounding the portlights. Very clean and durable. I’ll take some
pics tomorrow.
Doug
— In FreedomOwnersGroup@yahoogroups.com, “Al Lorman” <ajl@…>
Using foam backed vinyl practically guarantees that the foam will
fail at
some point, if not for you then for the next owner. Had I kept Ab
Initio
longer, I would have replaced the headliner with something solid,
like
plastic or Formica.
Al Lorman
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Jim
Demerest
additional teak
We like
panel from
Jim Demerest
I might use off-white Starboard, with groves to resemble tongue-ingroove.
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- “douglas.domurat” <douglas.domurat@…> wrote:
Hi,
pics tomorrow.
Doug
fail at
Initio
like
plastic or Formica.
Al Lorman
Demerest
additional teak
We like
panel from
Jim Demerest
Steve Gaber
Oldsmar, FL
