Posted by Doug Chace (ch47_av8r@…>)
Wilfred,
Thanks for the reply. Unfortunately, once the mast was broken
gravity took over and the top portion of the mast is now at the
bottom of that part of the bay.
I would be very pleased to receive any and all information regarding
retrofitting my F21 with an ALUMINIUM mast. I have 4 here at the
house now that have been given to me by sailors sympathetic to my
plight (amazing what you can find if you look in the right places).
I just need to know that I’m not wasting my time working on one of
those. I’ve seen the specs in the LINKS (I think) section here that
shows how to insert the mid-mast tabernacle, but there’s no info on
the mast (length, width, thickness required …).
I’ll check on the “Nonesuch”. Thanks again.
Doug
— In freedom21@yahoogroups.com, “Wilf Bishop” <wilf.bishop@…>
Hi Doug,
Is there any chance of you repairing the carbon mast? Although
creating an internal GRP sleeve for the mast and epoxying the broken
parts together over the sleeve would be rather a tricky job I guess
that there are composite shops out there who would be prepared to
take this on?
However please do consider an aluminium alloy mast - most of the
F21’s made over here in the UK were fitted with tapered aluminium
alloy masts and a few were fitted with non-tapered constant section
aluminium alloy masts which to my eye at least looked very “heavy” &
wrong. My UK mast was supplied by PROCTOR Masts who are now sadly no
longer in business. I’m sure that a USA supplier of aluminium masts
could fix you up with a replacement at a far lower cost than a Carbon
mast? Aluminium mast for the F21 DO NOT need stays if they are
designed right. If you wish I could measure-up the wall thickness of
my mast which is also sleeved with an internal aluminium tube
reinforcement in the lower parallel section of the mast - let me know
if this information would be useful. Lots of aircraft flying around
with unstayed cantilever aluminium alloy wings so there is nothing at
all special about carbon fibre masts its just that they are lighter
than aluminium alloy.
Maybe the Canadian built Nonesuch series of cat rig boats would
have a similar mast available which I understand are aluminium?
There is a Nonesuch around the 22ft LOA mark I understand - maybe
this would be worth investigating?
Yes I do know we spell aluminium oddly over here in the UK but for
me typing aluminum is really not instinctive. Good luck.
Wilf Bishop
To: freedom21@yahoogroups.com
Sent: Saturday, November 04, 2006 1:11 AM
Subject: [freedom21] Hello.
Hello one and all. I am now the proud owner of an F21. I believe
she is hull # 138 (HIN: TSP21 138M8 31). She’s a 1983 that’s in
overall very good condition with one major exception… her mast
is
broken. I got her for a song because of it, but now I’m finding
out
why the previous owner parted with her so readily. Does anyone
know
where I can get a used mast for the keel stepped version of the
F21?
I know that there’s a F21 for sale on E-bay right now, but that
would
only perpetuate the problem of having a boat without a mast. I’ve
checked with some manufacturers (GMT Composites, for instance)
received an initial estimate in the $6,000 range from each of
them.
Can’t do that, have too many kids to send to college.
I’ve seen some photos of what looks to be an aluminum mast
inserted
through the deck that has a hinge in the middle of it. If you’ve
done this, please contact me and let me know how difficult that
was
and if you had to install any other stays (fore, aft, port, stbd)
since the mast is aluminum and not CF. I’ve found that aluminum
masts are actually pretty easy to get (after posting on
CraigsList),
so that may be my best option.
I’ll get her cleaned up, fix the couple of voids in her gel coat
post some pics. I’ve read the posts from the last 8 months or so,
y’all are a dedicated bunch! Thanks in advance for any help.
Fair winds and following seas,
Doug
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.13.22/512 - Release Date:
01/11/2006
