Posted by Geoffrey Schultz (geoff.freedom@geoffschultz.org>)
I have a Freedom 40/40, hull #25, which was built in 1997. It’s been
9 years since I had the boat back near my home in MA, but this year
it’s sitting at Brewer’s Sakonnet in Portsmouth, RI and I’ve been
doing a lot of work on it. I’ve discovered a two issues that
certainly weren’t obvious, and perhaps warrant looking at on your boats.
I’m replacing the headliner due to the foam backing deteriorating
and I was quite surprised to discover that some of the bolts holding
the traveler assembly are leaking and the bolts are covered with brown
glop. The balsa core around these bolts is wet. I’ll be pulling the
assembly next time I go down to the boat and re-bedding the bolts. -
A majority of my portholes have water intrusion through the screw
holes on the outer ring. I’ve just finished rebedding all 14(?)
portholes with Sikaflex. That was a 3 days job…
You may want to look at this on your boat. I sure wasn’t expecting
what I found and without pulling the headliner, I wouldn’t have found
these.
