Holding Tank
Posted by Thomas Lynch (pass@…>)
I have an '87 Freedom 30 in Annapolis and my v-bert smells pretty bad around the holding tank. I’ve pumped it out, used odorlos, etc., but that only reduces the problem - it doesn’t go away. So I’m preparing to replace the hoses and the tank. Does anyone have a recommendation for a new tank manufacturer? The present tank is the “milk carton” type. I was hoping to move up to fiberglass or stainless. Any help would be greatly appreciated.
Tom
Quixote - Freedom 30
Ronco Plastics, Roto molded polyethylene, over 450 shapes. www.ronco-
plastecs.com
— In freedomyachts2003@yahoogroups.com, “Thomas Lynch” <pass@t…>
bad
but
preparing to
for a
type. I
be
Tom
Correction www.ronco-plastics.com 714 259 1385
— In freedomyachts2003@yahoogroups.com, “macks011” <macks04@o…>
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
type. I
would
be
Tom
I’ll second the Ronco (with the corrected URL) from whom I bought a new tank for our Freedom 28. Download the PDF catalog and wander through the many shapes available. They’ll put the fittings wherever you want. I added an inspection port and double vent lines. I’ve since learned that they can also add a “swizzle hose,” which is not the proper name for it, but it’s an open-ended hose inside the tank that, when hooked up to a water source, sprays around the inside, cleaning things out.
dge
Sent: Monday, August 30, 2004 4:04 PM
Subject: [freedomyachts2003] Re: Holding Tank
Ronco Plastics, Roto molded polyethylene, over 450 shapes. www.ronco-plastecs.com— In freedomyachts2003@yahoogroups.com, “Thomas Lynch” <pass@t…> wrote:> I have an '87 Freedom 30 in Annapolis and my v-bert smells pretty bad> around the holding tank. I’ve pumped it out, used odorlos, etc., but> that only reduces the problem - it doesn’t go away. So I’m preparing to> replace the hoses and the tank. Does anyone have a recommendation for a> new tank manufacturer? The present tank is the “milk carton” type. I> was hoping to move up to fiberglass or stainless. Any help would be> greatly appreciated.> > Tom> Quixote - Freedom 30
Posted by mail@… (mail@…)
I have the same problem. I replaced my hoses and it helped and have
been considering replacing the tank. If you end up replacing it
please post which one you went with and how it worked. I looked
through the 450 ones that Ronco has and none seem very close to the
unusual shape of the one in the F30. Good luck.
Bill
— In freedomyachts2003@yahoogroups.com, “David G. Evans”
dge
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
type. I
would
be
Tom
    Yahoo! Groups Sponsor
          ADVERTISEMENT
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
does anyone recommend moving the holding tank from the v-berth to under the port-side settee? I could get a bigger tank there and it’s not being used for anything.
-----Original Message-----From: mail@… [mailto:mail@…] Sent: Monday, August 30, 2004 11:05 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Holding TankI have the same problem. I replaced my hoses and it helped and have been considering replacing the tank. If you end up replacing it please post which one you went with and how it worked. I looked through the 450 ones that Ronco has and none seem very close to the unusual shape of the one in the F30. Good luck.Bill— In freedomyachts2003@yahoogroups.com, “David G. Evans” <dgevans@e…> wrote:> I’ll second the Ronco (with the corrected URL) from whom I bought a new tank for our Freedom 28. Download the PDF catalog and wander through the many shapes available. They’ll put the fittings wherever you want. I added an inspection port and double vent lines. I’ve since learned that they can also add a “swizzle hose,” which is not the proper name for it, but it’s an open-ended hose inside the tank that, when hooked up to a water source, sprays around the inside, cleaning things out. > dge> ----- Original Message ----- > From: macks011 > To: freedomyachts2003@yahoogroups.com > Sent: Monday, August 30, 2004 4:04 PM> Subject: [freedomyachts2003] Re: Holding Tank> > > Ronco Plastics, Roto molded polyethylene, over 450 shapes. www.ronco-> plastecs.com> > > > > > — In freedomyachts2003@yahoogroups.com, “Thomas Lynch” <pass@t…> > wrote:> > I have an '87 Freedom 30 in Annapolis and my v-bert smells pretty > bad> > around the holding tank. I’ve pumped it out, used odorlos, etc., > but> > that only reduces the problem - it doesn’t go away. So I’m > preparing to> > replace the hoses and the tank. Does anyone have a recommendation > for a> > new tank manufacturer? The present tank is the “milk carton” > type. I> > was hoping to move up to fiberglass or stainless. Any help would > be> > greatly appreciated.> > > > Tom> > Quixote - Freedom 30> > > Yahoo! Groups Sponsor > ADVERTISEMENT> > > > > > ------------------------------------------------------------------------------> Yahoo! Groups Links> > a… To visit your group on the web, go to:> http://groups.yahoo.com/group/freedomyachts2003/> > b… To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
I faced that choice on my F36 holding tank relocation project.
The port settee is prime storage space that I felt was too valuable
to use for tankage. But if the space is not being used, It is
certainly an easier installation.
under
have
Bill
bought
wherever
not
tank
dge
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
carton”
type. I
would
be
Tom
          ADVERTISEMENT
Yahoo! Groups Links
of Service.
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129mqst36/M=298184.5285298.6392945.30011
76/
D=groups/S=1705065792:HM/EXP=1094007946/A=2319498/R=0/SIG=11thfntfp/*
htt
p://www.netflix.com/Default?mqso=60185352&partid=5285298> click
here
<http://us.adserver.yahoo.com/l?
M=298184.5285298.6392945.3001176/D=group
s/S=:HM/A=2319498/rand=781651135>
Yahoo! Groups Links
Posted by Jay Whittle (jayw@…>)
Try:
Moeller Marine Products
36 Beach St.
Westerly, RI
02891
George Moore @ 401-596-2816
It’s what Freedom uses in the Legacy’s they make know.
For holding tanks (black water), wall thknss should be 0.25 minumum
Jay Whittle
Freedom Yachts, Inc.
Engineering Dept.
---------- Original Message ----------------------------------
Reply-To: freedomyachts2003@yahoogroups.com
Date: Tue, 31 Aug 2004 10:10:44 -0400
Bill
dge
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
type. I
would
be
Tom
          ADVERTISEMENT
Yahoo! Groups Links
of Service.
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129mqst36/M=298184.5285298.6392945.3001176/
D=groups/S=1705065792:HM/EXP=1094007946/A=2319498/R=0/SIG=11thfntfp/*htt
p://www.netflix.com/Default?mqso=60185352&partid=5285298> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=group
Yahoo! Groups Links
Listen to the “World’s Classical Radio Station”
http://www.beethoven.com
Great Music, Free Email, Exciting Bulletin Board!
Trim & stability issues if the tank is full?
Jay W.
Bill
dge
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
type. I
would
be
Tom
          ADVERTISEMENT
Yahoo! Groups Links
of Service.
ADVERTISEMENT
Yahoo! Groups Links
Posted by tlynchlaw (pass@…>)
Thanks to everyone who gave advice about my holding tank situation.
Here’s what I decided to do:
I had a polypropolene tank manufacturerd to the same dimensions as
the polyethelene tank I removed from the boat. I’m expecting it any
day now from cctech (gocctech.com) in Rhode Island. I also replaced
my hoses with odor safe hoses and sprayed the entire vberth floor
area where the tank sat with Raritan K.O. (as per Peggy Hall’s
recommendation in her book “Get Rid of Boat Odors”). Right now,
everything smells great – but of course I don’t have the new tank in
yet.
Once the new tank is in, I’m planning on adding a 1" through-hull
vent about 1 foot below the toe rail and very close to the bow to
allow air into the holding tank better. This is also Peggy’s
recommendation (which she gave me on her “headmistress” bulletin
board). I don’t like to add through-hulls, but the science seems to
make sense regarding killing off the odor-causing anerobic bacteria.
If anyone has words of caution about the through-hull, I’d be happy
to hear them. So long as I do it far enough forward I shouldn’t have
any water coming in even when heeling.
under
not
have
Bill
bought
wander
wherever
not
tank
dge
www.ronco-
plastecs.com
<pass@t…>
pretty
bad
etc.,
but
preparing to
recommendation
for a
carton”
type. I
would
be
Tom
If you’re worried about water coming in, even on a heel, you could
put a gate valve behind the through-hull for peace of mind…
— In freedomyachts2003@yahoogroups.com, “tlynchlaw” <pass@t…>
situation.
any
replaced
in
yet.
to
have
valuable
to
under
not
have
it
looked
Bill
bought
wander
wherever
I’ve
not
tank
inside,
dge
www.ronco-
plastecs.com
<pass@t…>
smells
pretty
bad
odorlos,
etc.,
but
I’m
preparing to
recommendation
for a
carton”
type. I
help
would
be
Tom
Posted by mdurki (vaughan@…>)
I advise crossing the intake hose to the tank; that is, if the head
is on the starboard side, lead the hose to the port side of the
holding tank. Mine was not set up that way and one day when we had
been sailing on a long reach, healed quite far, the joker valve gave
way, and you would not believe the mess! With the hose crossed over,
that cannot happen.
situation.
any
replaced
in
yet.
to
have
valuable
to
under
not
have
it
looked
Bill
bought
wander
wherever
I’ve
not
tank
inside,
dge
www.ronco-
plastecs.com
<pass@t…>
smells
pretty
bad
odorlos,
etc.,
but
I’m
preparing to
recommendation
for a
carton”
type. I
help
would
be
Tom
Be careful with CCTECH. I had a bad experience with them. They made
a custom tank for me and I found that it leaked after installation.
They eventually refunded my money, but it was a total PIA to fully
install the tank and find out it leaked. Before you install the
tank, plug all the holes except for the inlet and vent. Attach a
hose to the inlet and the vent and make them the same height above
the tank as they will be on the boat. Fill the tank with water till
it flows out the vent. Each foot of height equals approx 1/2 lb/ sq.
in.of pressure. If they are giving a warrentee of 3 lbs/ sq in.,
that
would be equal to 6’ of rise. Test it before you install it.
Instead of one vent, I installed two 3/4" vents. Now I have thru
ventilation. They are high on the topside, just below the toe rail,
and are never in the water.
– In freedomyachts2003@yahoogroups.com, “tlynchlaw” <pass@t…>
situation.
any
replaced
in
yet.
to
bacteria.
happy
have
<macks04@o…>
valuable
to
under
it’s
not
have
it
looked
to
Bill
bought
wander
wherever
I’ve
is
not
tank
inside,
dge
www.ronco-
plastecs.com
<pass@t…>
smells
pretty
bad
odorlos,
etc.,
but
I’m
preparing to
recommendation
for a
carton”
type. I
help
would
be
Tom
Thanks for the information. You really spooked me and now I’ll make sure I test the tank before installing it.
I also called CCTech to make sure they test the tank before sending it. They said they always pressure test and spark test? the tank, and the guy I spoke with said he doesn’t know of any tanks they’ve sent out that leaked or for which they returned someone’s money for a leak. However, you obviously know what happened to you, even if he doesn’t. Thanks again for the heads up. At least now they’re on notice that I’ll be testing the tank and have reason to be concerned about leaks!
-----Original Message-----From: macks011 [mailto:macks04@…] Sent: Wednesday, September 15, 2004 6:19 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Holding TankBe careful with CCTECH. I had a bad experience with them. They made a custom tank for me and I found that it leaked after installation. They eventually refunded my money, but it was a total PIA to fully install the tank and find out it leaked. Before you install the tank, plug all the holes except for the inlet and vent. Attach a hose to the inlet and the vent and make them the same height above the tank as they will be on the boat. Fill the tank with water till it flows out the vent. Each foot of height equals approx 1/2 lb/ sq. in.of pressure. If they are giving a warrentee of 3 lbs/ sq in., that would be equal to 6’ of rise. Test it before you install it.Instead of one vent, I installed two 3/4" vents. Now I have thru ventilation. They are high on the topside, just below the toe rail, and are never in the water.-- In freedomyachts2003@yahoogroups.com, “tlynchlaw” <pass@t…> wrote:> Thanks to everyone who gave advice about my holding tank situation. > Here’s what I decided to do:> > I had a polypropolene tank manufacturerd to the same dimensions as > the polyethelene tank I removed from the boat. I’m expecting it any > day now from cctech (gocctech.com) in Rhode Island. I also replaced > my hoses with odor safe hoses and sprayed the entire vberth floor > area where the tank sat with Raritan K.O. (as per Peggy Hall’s > recommendation in her book “Get Rid of Boat Odors”). Right now, > everything smells great – but of course I don’t have the new tank in > yet.> > Once the new tank is in, I’m planning on adding a 1" through-hull > vent about 1 foot below the toe rail and very close to the bow to > allow air into the holding tank better. This is also Peggy’s > recommendation (which she gave me on her “headmistress” bulletin > board). I don’t like to add through-hulls, but the science seems to > make sense regarding killing off the odor-causing anerobic bacteria.> > If anyone has words of caution about the through-hull, I’d be happy > to hear them. So long as I do it far enough forward I shouldn’t have > any water coming in even when heeling.> > — In freedomyachts2003@yahoogroups.com, “macks011” <macks04@o…> > wrote:> > I faced that choice on my F36 holding tank relocation project.> > The port settee is prime storage space that I felt was too valuable > > to use for tankage. But if the space is not being used, It is > > certainly an easier installation.> > > > > > — In freedomyachts2003@yahoogroups.com, “Thomas Lynch” > > <pass@t…> wrote:> > > does anyone recommend moving the holding tank from the v-berth to > > under> > > the port-side settee? I could get a bigger tank there and it’s > not> > > being used for anything.> > > > > > -----Original Message-----> > > From: mail@t… [mailto:mail@t…] > > > Sent: Monday, August 30, 2004 11:05 PM> > > To: freedomyachts2003@yahoogroups.com> > > Subject: [freedomyachts2003] Re: Holding Tank> > > > > > > > > I have the same problem. I replaced my hoses and it helped and > > have > > > been considering replacing the tank. If you end up replacing it > > > please post which one you went with and how it worked. I looked > > > through the 450 ones that Ronco has and none seem very close to > > the > > > unusual shape of the one in the F30. Good luck.> > > > > > Bill> > > > > > > > > — In freedomyachts2003@yahoogroups.com, “David G. Evans” > > > <dgevans@e…> wrote:> > > > I’ll second the Ronco (with the corrected URL) from whom I > > bought > > > a new tank for our Freedom 28. Download the PDF catalog and > wander > > > through the many shapes available. They’ll put the fittings > > wherever > > > you want. I added an inspection port and double vent lines. I’ve > > > since learned that they can also add a “swizzle hose,” which is > > not > > > the proper name for it, but it’s an open-ended hose inside the > > tank > > > that, when hooked up to a water source, sprays around the inside, > > > cleaning things out. > > > > dge> > > > ----- Original Message ----- > > > > From: macks011 > > > > To: freedomyachts2003@yahoogroups.com > > > > Sent: Monday, August 30, 2004 4:04 PM> > > > Subject: [freedomyachts2003] Re: Holding Tank> > > > > > > > > > > > Ronco Plastics, Roto molded polyethylene, over 450 shapes. > > > www.ronco-> > > > plastecs.com> > > > > > > > > > > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “Thomas Lynch” > > > <pass@t…> > > > > wrote:> > > > > I have an '87 Freedom 30 in Annapolis and my v-bert smells > > > pretty > > > > bad> > > > > around the holding tank. I’ve pumped it out, used odorlos, > > > etc., > > > > but> > > > > that only reduces the problem - it doesn’t go away. So I’m > > > > preparing to> > > > > replace the hoses and the tank. Does anyone have a > > > recommendation > > > > for a> > > > > new tank manufacturer? The present tank is the “milk > > carton” > > > > type. I> > > > > was hoping to move up to fiberglass or stainless. Any help > > > would > > > > be> > > > > greatly appreciated.> > > > > > > > > > Tom> > > > > Quixote - Freedom 30> > > > > > > >
Give my regards to Burt and Linda at CCTech, and tell them Marc from
Brooklyn says hello. By the way, I invested another $170 in the
failed tank to have it repaired by a local shop to no avail. I am
now having the tank made by Duraweld in Florida. I’ll let you know
how it turns out.
– In freedomyachts2003@yahoogroups.com, “Thomas Lynch” <pass@t…>
make
sending it.
out that
However,
be
made
installation.
till
sq.
that
rail,
situation.
as
any
replaced
floor
tank
in
yet.
hull
to
seems
to
bacteria.
happy
have
<macks04@o…>
valuable
berth
to
under
it’s
not
have
replacing
it
looked
to
Bill
bought
wander
wherever
I’ve
is
not
tank
inside,
dge
shapes.
www.ronco-
plastecs.com
<pass@t…>
smells
pretty
bad
odorlos,
etc.,
but
So
I’m
preparing to
recommendation
for a
carton”
type. I
help
would
be
Tom
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129gmjtf6/M=295196.4901138.6071305.30011
76/
D=groups/S=1705065792:HM/EXP=1095373195/A=2128215/R=0/SIG=10se96mf6/*
htt
p://companion.yahoo.com> click here
M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=828853955>
Yahoo! Groups Links
