Just thought that for those who have horizontal Propane Cylinders and have difficulty getting cylinders refilled. Here is the information document I keep on the boat and take to the propane filling station. It also helps to get the cylinders recertified, this need be nothing more than a physical inspection and the cylinder having a certification label attached by an approved propane cylinder inspector. The valves can be repacked or have the moving parts replaced if you have a repair shop willing to do it, but do not expect a valve replacement, they are not available.
Propane Cylinders.pdf (155 KB)
