So its been just over a year and I have done nothing with my spinnaker. Finally getting back interested in her. I had become discouraged last year because I discovered I would have to rework some things on my deck and it wouldn’t be a simple project. so it went onto the back burner and is finally back on the menu.
I have the gun-mount installed and am currently using some of the thin flexible kitchen cutting boards to line the inside of the gun-mount. something like this.
https://www.amazon.com/dp/B01HN7ZGUQ/ref=psdc_289863_t3_B00CRF2JAK
I intend to replace those cutting boards with UHMW tape I have found on amazon. it will basically be a thin layer uhmw with an adhesive back. like this
https://www.amazon.com/gp/product/B0191RP6JM/ref=s9_dcacsd_dcoop_bw_c_x_1_w
next i bought some 3/8" sta set and went to work figuring it all out. Only this time I got an actual experienced sailor and rigger to work it all out with me.
You basically have 4 sets of lines. 8 lines in total/
- your halyard.
- your down-haul
3&4, would be port and starboard reins
5&6, would be port and starboard control lines
7&8, would be port and starboard sheets
Now I have her rigged but have yet to fly, waiting on weather. once I have flown her I will work on a better deck layout. but this is what I have now.
- your halyard is run through the mast and was already run on my boat, should already be there for yours.
- down-haul is in the spinnaker sock. my spinnaker is in a sock that lays on the deck and has little ties to tie her to the stanchions or tow rail. the down haul is running through this sock to the head of the sail. I will know more when I finally get to run this sucker.
3&4, these lines tie or shackle to each end of the yard. they then run directly to the eyes and cam cleats on each side of the cockpit. yes, they really do just hang out in the open. maybe, it sure looks like that at this point. When the yard is put up they dont really seem to be much in the way. I have used one continuous run of about 80’ on this. each end is ties to the yard and its long enough to run through each eye and cam cleat and then still run all the way around the outside of the cockpit. we shall see how this works in practice. I have used an old line for this and will remeasure once I cut fresh line.
5&6, these lines slide the yard in and out of the gun-mount. each line is shackled or tied to each end of the yard. they then run to a block on the gun-mount, then to a block shackled to the anchor roller. from there they go to a set of eyes on the deck, and are routed to the cockpit. I am currently running both of these back to the cockpit along the port side of the boat.
7&8 are lines running from the cockpit, down the deck and to blocks attached to the base of the pulpit. from the base of the pulpit they go out to a block at each end of the yard. through that and attached to the clews on the spinnaker.
Alright folks, this is what the plan is, im heading out next chance I get so if something I have done strikes someone as a terrible Idea i am all ears!
Pictures to follow once I have everything sorted and run correctly
davidu
