Posted by Barry Stellrecht (yak@…>)
Hello, Vladimir (and other F33/F28 Owners)
I’ve got another one of those F33’s with deck problems where the centerboard
turning block goes through the deck. (I’ve also got deck problems elsewhere
which I’m repairing…so far, all very small areas except for between the port
winch & rope clutches that will probably be a square foot or two when I finish
digging out to fix it.)
Anyhow, now that I’ve got the headliner down I can see how that block works, and
re-constructing the deck around it looks to be an interesting problem that I
would appreciate ideas for…mine has the lower deck skin and balsa cut out in
a ~5inch circle around that block, with a SS backing plate that has a socket
which fits inside a SS compression pipe going down toward the centerboard with
the pennant running inside it. The bottom of the post sits on a large U-shaped
piece of fiberglass inside the trunk which has a tube going thru to stop it
dropping out near the top and some sort of pin going through it at the bottom.
(I haven’t seen the bottom one since I don’t wanna deal with taking the board
out this time!)
Up on the top, there are a couple (slightly rotting) donut-shaped pieces of
plywood above the backing plate. When the block takes the load of the board,
the deck flexes, and the ply compresses until the compression post takes up the
load.
So far my repair ideas are:
Reinforce the top skin of the deck with extra layers of biax cloth & epoxy,
out as far as the rotten core goes (probably another inch or two beyond the
existing hole. (I could dig out more core than just what is failed here) -
Replace the balsa around with something sturdier (probably plywood except at
the edge where it might get water exposure at the bolts and pennant
hole–thickened epoxy there. -
Build up the bottom skin a bit too around this area. This can go out a bit
further than the replaced core…perhaps six inches out? -
Try to shim up the compression post somehow so it will take the load before
the deck flexes. (Right now I’ve just bent a bit of 1/8" steel wire/rod around
the joint as a stopgap measure while I’m hauling the board up/down to do bottom
paint on it & the trunk.
For those of you with this problem, what have you tried/considered and how did
it work?
Barry
vladimir_ud wrote:
There is a block on cabin top. it’s turning point for the line for
lifting centerboard. This block supports all weight of the plate. I
have seen four F28-33 boats. All had fiberglass cracked, core
saturated around this block(Mine boat included)
s/v Flutterby, Freedom 33 cat ketch (becoming a junk rig)
