Does any have or know of somewhere to get a schematic of the rudder and bearing assemblies for a 1984 Hoyt 32? I have read various posts in the forums about the packing being the bearing as well as there being delrin bearings. The bolts on my lower bearing ring are maxed out so I need to add new packing but with the play I just assume change everything in the lower bearing housing if in fact there is some sort of solid bearing.
If anyone has any experience or information of a Hoyt F32 lower rudder post bearing I would appreciate it.
I did contact Tides Marine as I’ve seen them mentioned in the forums a bunch of times, but they could not help.
