The ATN climber (name?) is about
$400. To rent the marina crane is $150 plus $70/hr labor or your labor.
So again I am taking the high road and it would seems to me that a good portion
of the people on this forum are not youngsters, rent the crane its safer!!!
There is nothing up there that is do or die and needs immediate
attention. VHF all of us should have a handheld for dingy use, wind vane use
some record cassette tape tied on a halyard will help, anchor steaming light
use your portable cockpit light pulled half way up with the spinnaker or jib
halyard where other boats can actually see it.
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of george huffman
Sent: Thursday, May 08, 2008 8:04
AM
To:
Re: I want to install Mast Steps
Hey Alan,
A grigri, (or other device like it) could be a good added safety device if you
attach it such that it can’t get out of your reach. The Top Climber is
nice but I’ve set my jumars up in such a way that I’m more like stair climbing
than inch worming my way up the mast. I’ve learned that it’s not even
enough to focus on the task at hand and think every move through before making
it (not my forte) but that I need to think the entire process through from
start to finish. I too once did the nautical equivelant of painting
myself into a corner. Maybe we should make lapel pins…
I was anchored out near Poquoson Va. for a couple weeks doing boat mainenance and letting
my little retirement check catch up with my budget before shoving off for Block Island and points north. I needed to replace
the antenna for the VHF that was located on my Missen Mast (Allied
Princess). I took a very long line that I always have onboard and rigged
it through a set of vang blocks, hoisted that aloft and simply pulled myself
aloft. I was using the Prussic Knot safety method I’ve described
before. I finished the antenna install about the time that I could no
longer feel anything in my legs from blood circulation loss. When I tried
to lower myself I found that the tail end of the line had fouled itself on deck
hardware! There was very little boat traffic in my little corner of Va. and whenever I tried
to hollar and wave someone over they would point and swerve… away! They
thought I was yelling for wake abatement. I really didn’t feel safe tring
to climb down with no feeling in my legs and was wondering if I would ever walk
the earth again. At last I got the tail end of that line free by
laboriously whipping it around from aloft. heh heh Live and learn
eh? So your point concerning compelxity is well taken Alan.
Alan Kusinitz
<akusinitz@yahoo.com> wrote:
Just a comment on complexity. I use an ATN
Top climber (www.atninc.com). It
seems quite safe and you can go up on your own.
The first time I used it I decided to add
further redundancy/complexity. On a separate line I attached one of
those “climbers gadgets” that you have to release to slide down the
rope and that was hooked to the ATN as well.
Going up was no problem. On the way down I
got myself into a situation where the mechanism on the ATN had tension on it
(could not be released) and there was also tension on the safety I set up (I
forgot to release it before lowering the next stage on the ATN).
No chance of falling but I was near the
top of the mast and it was early evening. I actually wondered if I’d be
spending the night.
Eventually I managed to create slack so I
could get down but it was quite a struggle.
In this case the complexity and a user
error combined.
Alan F-33 1982 SEAPR
Sent: Wednesday, May 07, 2008 7:22
AM
Alternatively you can make up a prussic knot around the mast with a big
loop of 1 inch tube strap and carabiner to your harness/chair. If you are
going to encounter spreaders you will need two of these so you can hook on
above the obstacle before you unhook from below. It does add a step to
your ascent if you are self ascending or you have to manage it while being
hoisted aloft. But remember, complexity that add’s safety is a good thing
in this case. A safety line of some sort is just good protocal as well as
a great way to avoid getting into the Darwin awards.
sgaber@tampabay.rr.com
That’s why any time you go up a mast, even with mast steps, you should
have a halyard attached to a harness or a busun’s chair, with somebody on deck
to tie it off. Or use one of those climber’s gadgets that alllow the line to be
held at any point so you don’t need anothe hand.
A safety line is or should n\be mandatory. This ain’t the 19th Century.
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- Jay Glen <svfantasy@gmail.com>
Hi Lola,
I think you have mistaken me for Randy who inquired about attaching mast
steps to his carbon fiber mast. I advised against it, or, using mast steps
at all. They can be very dangerous as you never know when they will fail
due
to corrosion or poor installation. I believe you are referring to
rat-lines,
which are ropes strung between the lower shrouds on small vessels. They
were
used to climb aloft back in the days of old sailing ships. The problem
with
using them today is excessive windage and aesthetics. The safest way to go
aloft? Have someone else go up for you!! Smile…On Sun, May 4, 2008 at 11:30 AM, Lola Jackson <lolaltd@yahoo.com> wrote:
Hi Jay, Have you thought of a rope ladder. I see then on other boats
and they look neat I think. The ones I mean seem to come in at an
angle…I’m sure one of the other sailors here that are more
experienced can
tell you what I mean. They look like you leave it up all the
time…LolaF30Jay Glen <svfantasy@gmail.com>
wrote:Randy,
If you had an aluminum mast and wanted to provide yourself with a
stable
secure working platform, I would recommend just installing two mast
steps at
equal height just below the top to provide a place to stand on while
doing
your work aloft. You would still have to be hoisted in a chair, but
at least
you would have a place to stand to help relieve the discomfort of the
chair
or harness. But, you have carbon fiber, so I’m glad you decided to
scrap
this idea.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try
it now.
it now.
