Ideal V3C windlass
Hello Group,
Anyone out there have an Ideal V3C verticle windlass. My Freedom 40
has one installed. The wildcat and capstan seized together making it
impossible to operate the capstan or wildcat independantly. After
dismantling the windlass I was able to seperate the two items.
However, even after cleaning and lubricating the metal mating surfaces
of the capstan and wildcat, they still are so tight they will not
rotate independant of one another. Any ideas? I’ve emailed Ideal but
have not heard back as of late. I’m going cruising Friday and would
like to get it back together.
Jay
F-40
San Francisco Bay
Jay,
Are you sure the capstan (I suppose that is the rope drum) and
wildcat (I suppose that is the chain wheel) have to be able to
rotate independently? I just dismantled, cleaned, greased and
relocated the Maxwell 1200 vertical windlass on my boat, and on the
Maxwell the drum and chain wheel cannot turn independently.
— In freedomyachts2003@yahoogroups.com, “Jay Glen” <svfantasy@…>
Hello Group,
40
it
surfaces
but
would
Jay
F-40
San Francisco Bay
Not sure I can agree. Can’t speak for the V3C, but I also have a
Maxwell 1200. If you loose the top cap (turn counter clockwise) the
wildcat will run free allowing you to launch the anchor. In this way
they do turn independently. When you tighten the top cap, the wildcat
and capstan do not turn independently.
Posted by svfantasy@… (svfantasy@…)
Michel,
The Ideal vertical windlass (V3C) is designed to allow the capstan and wildcat to operate independantly. In doing so, you can use the capstan to warp the boat out of a slip and not have to remove the chain from the wildcat. The capstan operates all of the time, however, by tightening a friction brake the wildcat then is also engaged. I was surprised to hear from Ideal at 8 PM Pacific time last night. They advised to use emery cloth to remove enough metal on the capstan hub to allow free movement of the wildcat.
Jay
----- Original Message -----From: “michel.capel” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Ideal V3C windlassDate: Thu, 10 Aug 2006 09:15:22 -0000
Jay,Are you sure the capstan (I suppose that is the rope drum) and wildcat (I suppose that is the chain wheel) have to be able to rotate independently? I just dismantled, cleaned, greased and relocated the Maxwell 1200 vertical windlass on my boat, and on the Maxwell the drum and chain wheel cannot turn independently.Michel— In freedomyachts2003@yahoogroups.com, “Jay Glen” <svfantasy@…> wrote:>> Hello Group,> > Anyone out there have an Ideal V3C verticle windlass. My Freedom 40 > has one installed. The wildcat and capstan seized together making it > impossible to operate the capstan or wildcat independantly. After > dismantling the windlass I was able to seperate the two items. > However, even after cleaning and lubricating the metal mating surfaces > of the capstan and wildcat, they still are so tight they will not > rotate independant of one another. Any ideas? I’ve emailed Ideal but > have not heard back as of late. I’m going cruising Friday and would > like to get it back together.> > Thanks,> > Jay> F-40> San Francisco Bay>
Michel,
Maybe your windlass needs service also? It sounds like your Maxwell is set-up the same as an Ideal.
Jay
----- Original Message -----From: “jerry_magic1” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Ideal V3C windlassDate: Thu, 10 Aug 2006 15:07:48 -0000
michel.capel wrote:> Are you sure the capstan (I suppose that is the rope drum) and > wildcat (I suppose that is the chain wheel) have to be able to > rotate independently? I just dismantled, cleaned, greased and > relocated the Maxwell 1200 vertical windlass on my boat, and on the > Maxwell the drum and chain wheel cannot turn independently.Not sure I can agree. Can’t speak for the V3C, but I also have a Maxwell 1200. If you loose the top cap (turn counter clockwise) the wildcat will run free allowing you to launch the anchor. In this way they do turn independently. When you tighten the top cap, the wildcat and capstan do not turn independently.
Well Jay, you may be right, but when I had the drum and wheel off
the axis that comes from the motor down below, I found two keys that
hold the drum and chain wheel in place, and these keys definitely
don’t want to move independently…
— In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:
Michel,
Maxwell is
Jay
on the
way
wildcat
Jerry, you’re absolutely right; I forgot the manual operation of the
clutch.
— In freedomyachts2003@yahoogroups.com, “jerry_magic1”
way
wildcat
Hello Michel,
I just finished cleaning and reassembling my Ideal windlass and now it works as designed. By loosening the capstan cap the wildcat is free and the capstan does the work, tighten the capstan cap and both the capstan and wildcat now operate. I do appreciate your input.
Jay
Freedom 40 “Fantasy”
SanFrancisco Bay
----- Original Message -----From: “michel.capel” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Ideal V3C windlassDate: Thu, 10 Aug 2006 20:48:27 -0000
Well Jay, you may be right, but when I had the drum and wheel off the axis that comes from the motor down below, I found two keys that hold the drum and chain wheel in place, and these keys definitely don’t want to move independently…— In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:>> Michel,> > Maybe your windlass needs service also? It sounds like your Maxwell is> set-up the same as an Ideal.> > Jay> > ----- Original Message -----> From: “jerry_magic1”> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Re: Ideal V3C windlass> Date: Thu, 10 Aug 2006 15:07:48 -0000> > michel.capel wrote:> > > Are you sure the capstan (I suppose that is the rope drum) and> > wildcat (I suppose that is the chain wheel) have to be able to> > rotate independently? I just dismantled, cleaned, greased and> > relocated the Maxwell 1200 vertical windlass on my boat, and on the> > Maxwell the drum and chain wheel cannot turn independently.> > Not sure I can agree. Can’t speak for the V3C, but I also have a> Maxwell 1200. If you loose the top cap (turn counter clockwise) the> wildcat will run free allowing you to launch the anchor. In this way> they do turn independently. When you tighten the top cap, the wildcat> and capstan do not turn independently.>
