IMPORTANT MAP INFORMATION
Hi All,
I’m up to date with adding boats to our map. If your boat is not
listed it is because you sent your data to me via this discussion
instead of using the online form at
http://www.freedom21.info/maprequest.htm.
Looking back through the messages I see more than a dozen boats that
have not appeared on the map. Sending me a message saying that your
boat is located near a lake, river, or bay somewhere doesn’t help me
put your boat on the map. You will need to provide latitude and
longitude coordinates. Instructions on how to obtain your
coordinates are supplied on the map request page listed above. If you
follow the instuctions fully, you will be able to zoom in on the
satellite view and see the actual slip where your boat is tied up.
If you only provide low resolution coordinates, you will not be able
to find your boat.
If your boat is not on the map, go to the online form and fill it out
completely and I will have your boat on the map ASAP.
Again, please do not use this discussion to send your boat location.
Use the Map Request page http://www.freedom21.info/maprequest.htm
instead.
Happy New Year,
Max
