Posted by rocclear (aronella@…>)
Does anyone know where I can get insect screens for the hatches and
companionway of a 1994 Freedom 35? How have people dealt with this?
Can I get screening and just “place it”?
Louis Spitz
Louis Spitz
The solution for me was to purchase insect screening from a camping
supply outfit (ex: Campmor) that has very small holes (Excludes
no-seeums) , and create a lightweight frame using 5mm Luan plywood. I
glued this screening to the framing and use self-adhesive Velcro to
fasten it to the wood framing surrounding each of my hatches. A
similar approach works for the companionway opening where two hatch
boards made of the same 5mm plywood with large openings covered with
screening works fine. Herm
Can I get screening and just “place it”?Thanks,
Louis Spitz
Posted by f35sail (s.goward@…>)
Louis:
Please switch to FreedomOwnersGroup in Yahoo. This group is
contaminated with SPAM.
Louis Spitz
Posted by Sailor (ketch_sailor@…>)
For forward opening deck hatches try a baby supply store (Babies-R-Us, etc.) for the netting that goes over baby strollers and baby carriages. The netting is quite fine, and has an elastic hem that streches over the open hatch and holds the base of the netting in place. I think I paid about $6. Rick Wright s/v ANNIE Davis Crk, MDHerman and Gail Schiller <hschiller2@…> wrote: The solution for me was to purchase insect screening from a camping supply outfit (ex: Campmor) that has very small
holes (Excludes no-seeums) , and create a lightweight frame using 5mm Luan plywood. I glued this screening to the framing and use self-adhesive Velcro to fasten it to the wood framing surrounding each of my hatches. A similar approach works for the companionway opening where two hatch boards made of the same 5mm plywood with large openings covered with screening works fine. Herm.At 09:49 AM 8/26/2007, you wrote:>Does anyone know where I can get insect screens for the hatches and>companionway of a 1994 Freedom 35? How have people dealt with this?>Can I get screening and just “place it”?>>Thanks,>Louis Spitz>>
Pinpoint customers who are looking for what you sell.
Posted by louis spitz (aronella@…>)
great ideas! Thanks much, Rick and Herm.
Lou
Sent: Monday, August 27, 2007 12:04 PM
Subject: Re: [freedomyachts2003] insect screens for Freedom 35
Rick Wright
s/v ANNIE
Davis Crk, MDHerman and Gail Schiller <hschiller2@suddenlink.net> wrote:
The solution for me was to purchase insect screening from a camping supply outfit (ex: Campmor) that has very small holes (Excludes no-seeums) , and create a lightweight frame using 5mm Luan plywood. I glued this screening to the framing and use self-adhesive Velcro to fasten it to the wood framing surrounding each of my hatches. A similar approach works for the companionway opening where two hatch boards made of the same 5mm plywood with large openings covered with screening works fine. Herm.At 09:49 AM 8/26/2007, you wrote:>Does anyone know where I can get insect screens for the hatches and>companionway of a 1994 Freedom 35? How have people dealt with this?>Can I get screening and just “place it”?>>Thanks,>Louis Spitz>>
My cousin found some screening that was attached to a circular tube
of sand. You lay it outside on the deck over your hatches and open
them from inside. I thought this was a very ingenious solution to
the problem of insect control. Because the screening is on the
outside, you can open and close the hatch from the inside without
moving the screen.
Good luck
TW
Louis SpitzNo virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.484 / Virus Database: 269.12.10/977 - Release Date:
8/28/2007 4:29 PM
Version: 7.5.484 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007 4:29
PM
