Hi,Is this the drill I need?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=120309240894Thank you…I will need to get the bit and Charger, I understand.Lola
Posted by katorpus (jrb@…>)
Lola
Since the battery (not included in that e-bay listing) retails for $209
(discounted below at $142.95 plus shipping) and you’d still need the
charger, you would be better off buying the drill here…
http://www.tylertool.com/miel47.html
$315 plus $8.95 flat rate shipping…INCLUDES a battery and the charger
If you need a second battery, those are $142.95 at the same place
http://www.tylertool.com/mibachandcot.html
Note that the drill is presently backordered
You might find a better deal somewhere else…I just found that on
google for you
John
— In FreedomOwnersGroup@yahoogroups.com, Lola Jackson <lolaltd@…>
Hi,
Lola
Posted by Bob (rweeks6508@…>)
You need the charger and battery … this is marketing foo-foo at its best. Cant use the drill unless you get a battery and cant charge the battery unless you have a charger! Will add ~$100+??BobOn Mon, Sep 29, 2008 at 6:29 PM, Lola Jackson wrote:Hi, Is this the drill I need? http://cgi.ebay. com/ws/eBayISAPI .dll?ViewItem&ssPageName=STRK: MEWAX:IT&item=120309240894 Thank you…I will need to get the bit and Charger, I understand. Lola
Posted by Roger L. (rogerlov@…>)
Over $100. But it’s the right tool. That’s the same V28 Rt angle drill I use to raise the main on my F28. It is the Cadillac and a battery will last all weekend for raising and unreefing. I recommend a spare battery and the charger of course. The extra battery comes in handy. If you get the V28 hand held flashlight to go with it be sure and get extra V28 bulbs, too. A dandy flashlight…it probably gets as much use as any tool on board…but it is hard on bulbs.
Roger L.
Cc: freedom group
Sent: Tuesday, September 30, 2008 7:33 AM
Subject: RE: [FreedomOwnersGroup] Is this the correct drill?
Bob
Hi,
Lola
