Had our 1993 Pedrick designed Freedom35 recently hauled at the end of the season and noticed some water in the v-berth. Had noticed minor water presence during the season in the head (toilet paper roll swollen?) and in the locker over the galley. Thinking maybe coming from stanchions?If so, how would I confirm, and more importantly, best way to address.
Could be the toe rail as well. Accessing those nuts under the deck could be a very difficult task that would require dismantling the interior cabinetry.
Getting at most of the toenail bolts isn’t that complicated - in the v berth it’s a matter of removing screws and the cherry molding piece. - many of the rest are inside the cabinets But also suggest look at port lights - the usual suspects
How common is the toe rail the culprit? Was leaning more towards stanchions as the problem through years of shrink wrapping compressing the stanchions during the winter months.
Anything is possible- and as Camino said - it could also be portlights. Best thing to do is use a hose and flood each stancion while someone is down below looking for drips. You can use toilet paper to spot leaks by pushing it up against the hardwear under the deck. If it’s soggy, you found the leak. Work uphill - starting at the deck scuppers.
As a Freedom 35 owner, I am aware of the leak issue in the vee berth. Try recaulking the deck ring around the mast. A favorite leaking spot.’
s
