Posted by billpeggyweber (billpeggyweber@…>)
I’m trying to rig something that would help me pull the motor out of
the water when I’m resdy to sail. I just bought a 6h.p yamaha 4
stroke and it weighs 88lbs. I way 135lbs. I’m thinking a rear
stanchion and some type of block and tackle.
any ideas???
Posted by Joe Conron (jconron@…>)
If you have a stern rails, you can attach a 4 part system using two fiddle
blocks: one with becket and cam cleat. Attach the shackle on the fiddle with
cam cleat to a fitting on the stern rail and attach shackle of other fiddle
to something on the motor or mounting pad assembly.
I used this on another boat where the motor was 90 or so pounds and it
really helped. In my case the motor was a long reach when in the down
position due to high freeboard.
Regards,
Joe Conron
-----Original Message-----
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On
Behalf Of billpeggyweber
Sent: Wednesday, March 29, 2006 2:50 PM
To: freedom21@yahoogroups.com
Subject: [freedom21] lifting outboard up before sailing
any ideas???
Yahoo! Groups Links
