As it is starting to get cold here in New England, I am concerned that
the map has me in the middle of Nantucket Sound! Wet and Cold!
Max, I went thru the steps you outlined in your message, and have to
change my location to 41.61618,-70.430646. Can you make the change to
the map? Thanks–Bob
Bob,
Take a look at the newly published map and let me know if that is
more accurate. If it is not, it may be because you didn’t center
your location on the map by double clicking on it.
I hope this helps.
Max
that
to
to
the map? Thanks–Bob
Way to go, Max!! I am no loger lost in the Sound, and happily, warm
and homeported in Cotuit, Cape Cod! Thanks! Bob
— In freedom21@yahoogroups.com, “Max Lent” <maxlent@…> wrote:
Bob,
I hope this helps.
Max
that
to
change
to
the map? Thanks–Bob
