Posted by Payne, Doug (doug.payne@…>)
We have a Mull
28, mostly day sail it but we have weekended on it a number of times. The quarter
berth is huge, as big as many 35 footers as the boat carries its beam well aft.
If you consider that storage space, vs a berth, then along with the other space
Herm mentions, it has quite a bit. For a couple, I have always felt the boat
was equivalent to most 30 footers. It is one huge 28 like all the Freedoms,
they seem to size about 2 feet bigger than their actual size, especially for
their era.
Doug
Douglas M. Payne
Managing Partner - Dallas Ft. Worth
Tatum, LLC
5400 LBJ Freeway
Suite 800
Dallas, TX 75240
office ••• 972.200.1555
mobile ••• 972.953.8065
fax ••• 972.200.1349
doug.payne@…
www.tatumllc.com
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Herman and Gail Schiller
Sent: Monday, August 06, 2007 9:10
AM
To:
Re: Looking for Hoyt F32, Hoyt F33, Mull 30
(maybe M36)
Storage is not the Mull
28’s long suit. The aft quarter berth has the
fuel tank under it, the settees have water tanks under them, and the
waste tank takes up some of the area under the V-berth. I added
narrow shelves on the upper sides of the V-berth area (similar to the
ones I had in my Freedom 25). There is some room behind the settee
back cushions, and an area at the forward end of the port settee.
However, the boat does have a hanging locker, and a huge cockpit
locker area (which needs some structure to exploit its volume. The
quarter berth is large, probably able to accommodate a 300-pounder.
There is good storage in the main cabin for books, and a small
cabinet for smallish items. The galley has limited storage, but has a
cute hatch to enable throwing trash into a can in the cockpit locker.
There is no room in the bilges for storing anything. Surprisingly, I
was told the first owner was a liveaboard. Herm
At 10:20 PM 8/5/2007, you wrote:
The M28 is indeed on the small side, although I can imagine that the
open quarter birth is more user friendly. We want to be able to spend
month on board, or at least use it as out base, so storage is very
important.
Attachment: (image/gif) image001.gif [not stored]
