LOL…
Yep, I have the same experience.
That’s why I have “friends in the business”
and buy a lot of stuff off the beaten track.
We will paint a gallon of ablative on Emmylou.
Will post pix before she is splashed.
Sean
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of julius christensenSent: Monday, March 05, 2007 10:36 PMTo: freedom21@yahoogroups.comSubject: RE: [freedom21] Re: Maccochaque Restoration
Sean,
Hard paint is just what it say’s, hard, stays on year after year. Ablative is paint that will gradually wear away with use.It bleeds off and emits chemical agents to prevent growth of slime, algae and barnicles.Epoxies are usually 2 part mixes that are rock hard.As far as prices go,they are so varied I can’t explain it.Some paints vary100 bucks just from one supplier to another.If you buy it at Fawcetts in Annapolis you can pay as much as 350 bucks for a gallon of paint that you can buy at West Marine for much less.I bought halyard for my boat for 96 cents a ft. at the beginning of the season last year.2 months later I found it online at a clearance price of 14 cents a ft. I bought another 100 ft. Boating prices are so unexplanable I can’t even begin to understand.
BiffSean Mulligan <quadmulligan@yahoo.com> wrote:
Thanks - I am on Defender right now.
Anyone want to weigh in on ablative vs. hard?
Not that we’re seriously racing…
But we take on boats twice our length…
(and we like to turn their heads!)
What’s the dif between $100 and $150 a gallon?
Speedy Sean
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of julius christensenSent: Monday, March 05, 2007 7:41 PMTo: freedom21@yahoogroups.comSubject: RE: [freedom21] Re: Maccochaque Restoration
Sean,
It took less than 1 gal. to paint my full keel F-21. The people at West Marine say there is a shelf life on anti-fouling paints.Don’t buy more than you need.Has anyone tried the new
anti-fouling paint Rust-oleum has out. You can buy it for 30 bucks a quart. It is sold at Lowes.Try www.defender.com for better prices on paint.
BFN
I’m interested in the “101” product for re-bedding stanchions as well.
That’s on the “to-do” list along with installing bow chocks.
I’ll ask my friend at West Marine what he suggests.
Ordered 1/16" lead sheet to fair into the bottom of our keel.
Will need lots of sanding, stripping, filling and fairing before paint.
Anyone have experience with how many gallons of Petit Trinidad it takes?
It’s not Spring here yet - but in a couple of weeks I’m going to start work.
Bought a random orbital buffer for $20.00 at Auto Zone.
I love the idea of F21 owners putting out the invite for others to come sail.
Seeing (from the map) how many are in the NE, it shouldn’t be too hard.
Sean / Vivian - Emmylou, Stamford, CT
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Doug ChaceSent: Sunday, March 04, 2007 10:13 PMTo: freedom21@yahoogroups.comSubject: [freedom21] Re: Maccochaque Restoration
Chris, Meeting on the Bay sounds great. By the way, THANKS for the 5200 warning. That is exactly what I was going to use on my stanchion rebed. I’ll see if I can find some 101 (also a 3M product?) or ask around to some of the Old Salts at our Marina.Spring is here and I’m itching to launch MY 21.Doug— In freedom21@yahoogroups.com, “chris montgomery” <freedom.sailingguy@…> wrote:>> — In freedom21@yahoogroups.com, “Doug Chace” <ch47_av8r@> wrote:> >Doug–You must be very judicious in your selection of > sealants/ashesives. 5200 is an adhesive and should not be used on > anything that you might want to undo/remove anytime in the future. > DON’T use it to rebed stancions, or any other deck gear. Use 101 if > you can find it. There are some other sealants that work as well, > but I’m not familiar with the brand names. If you have any other > questions regarding your refit, feel free to email throuogh this site > and I think that my home emeil is on the members section.> > I see that you are from DC. I grew up there. I now live in Newport > News, but am soon to move to Middlesex on the Pianatank where I keep > Sook, My 21. I assume that you will be sailing the Chesapeake. If > you ever want to rondevous get in touch. There are some beautiful > anchorages in my area. Also, I’m hoping to sail up the bay this > summer to visit on the Choptank and the Wast River. Hope that your > restoration continues to go well.> > Chris,> > > > After much reading (and what SHOULD have been common sense from the > > beginning), I have realized that you are right. On building > houses, > > I’ve done everything from plumbing to frame in to finish work to > > brick and mortar… never electrical. And my reason for this? If > > you mess up on the plumbing, you need a ShopVac. If you mess up on > > the electrical, you can burn somebody’s house down. I am sure that > > the same holds true for a boat – MY boat. Tinned wire it is.> > > > I’ve mounted the steaming light and the anchor light (pictures to > > come soon) and found a great fix for the opening top of the mast. > I > > picked up a 3" PVC end cap at Lowe’s. The outside diameter of the > > mast is right around 3 1/2". The inside diameter of the end cap is > > about 3 15/32". So, just under 10 minutes with my Dremel tool and > I > > had a “hand and glove” type of fit. I used 5200 to seal it on > tight > > and covered it in electrical tape like I’ve seen so many of you Old > > Salts do.> > > > The rudder assembly is finally ready. I’ve finished painting, > > cleaned up the SS fittings, completed the tiller (7 coats of Spar > > Urethane SHOULD be enough for now), and put everything together. > The > > bottom paint isn’t the exact color I thought it would be, but I > think > > it will work.> > > > I am SO glad this site is here!> > Thanks again,> > Doug> > > > — In freedom21@yahoogroups.com, “chris montgomery” > > <freedom.sailingguy@> wrote:> > >> > > — In freedom21@yahoogroups.com, “Doug Chace” <ch47_av8r@> wrote:> > > >Doug–I wouldn’t consider anything but the best when it comes to > > > wiring. I’m a bit biased as an electrician, but do you want to > do > > > the job again and soon? The difference in cost isn’t very much > all > > > things considered and a short can get fiberglass/carbon to burn > and > > > it’s almost impossible to put such a fire out. Chris> > > > All, > > > > My restoration of #138 is in full swing. Due to the weather, > > I’ve > > > > moved operations into my basement (and isn’t my wife HAPPY!). > > > Today > > > > was a banner day in boating maintenance/repair for me.> > > > > > > > I finally got the stain from the tiller off the rudder and have > > > begun > > > > painting. (You’ll see some pics posted)> > > > > > > > I’m also rebuilding another tiller that I got from > another “shade > > > > tree” boat guy like myself. He tried to extend it about 8" by > > > using > > > > fiberglass and got horrible results. (A psuedo-“after” pic is > > > posted, > > > > I need to find the before… it’s awful.)> > > > > > > > The mast is going along swimmingly. I cleaned (inside and out) > > it > > > > and waxed it so now it’s all shiny. I know that several > > somebodies > > > > will probably tell me that I wasted my time waxing, but I had a > > > blast > > > > doing it… so did my son. I’ve got the main and spin halyards > > run > > > > (that was a chore), the windvane mount installed, the lighting > > > > ordered, and am looking at wiring. > > > > > > > > If I’m only going to be sailing freshwater, > will “indoor/outdoor” > > > > wiring be o.k since it will essentially be sealed inside the > > mast. > > > > Or, do I really need the “tinned marine” wire. I know that > there > > > are > > > > previous posts about this… but does fresh vs. salt make a > > > > difference? By the way, be prepared with a LOT more questions > on > > > > wiring. I’m a framer/roofer/landscaper/plumber kind of guy. > > This > > > > will be my first experience with routing the “juice.”> > > > > > > > Next up is to re-finish all the wood in the cabin, “Fabreeze” > the > > > > cushions, and see what else I can do while its 6-32 degrees > > outside.> > > > > > > > For those purists out there who don’t like to see the Group > > > cluttered > > > > with spoonfeeding the newbie, please feel free to > contact/coddle > > me > > > > directly. :)> > > > > > > > Looking forward to MANY more days like today!> > > > Doug> > > >> > >> >>
