Main sail jammed
Posted by David Grounds (drdgdo@…>)
I recently took my freedom 21 out and couldn’t get the
main sail to go all the way up. This was not pretty.
Anyways, does anybody have any suggestions as to how I
can lube the track, and is this a common thing?
Dave
— Nick <blueraven1@…> wrote:
Phil,
Although I have not used it yet, I have seen many
postings which said
they used Spartite to form a collar.
www.spartite.com
Go to their web site and read FAQ. If you grease
the hull side of
the hole the mast will not stick to the boat if you
need to pull it
out.
You can also ask a boat yard for a estimate to do it
for you. Pick
one that has done it before.
Maybe a F-21 owner has used Spartite and will post a
reply.
Nick Marino
“Blue Raven”
F-21, #295
— In freedom21@yahoogroups.com, “Allen McClung”
<amcclung@…>
Phil,
The spacer you need is a rubber thing which keeps
the mast from
banging against the hole. I can take a digital
picture if you like
put a ruler next to it. I don’t have a clue where
to tell you to go
buy one.
— In freedom21@yahoogroups.com, “knappphilip”
<filnap@> wrote:
I have recently purchase a Freedom 21. Can some
tell me what
type
of
spacer or sleeve I’m to use between the free
standing CF mast and
mast tube? I seem to be missing that item!
Phil Knapp
Freedom 21
Port Isabel, TX.
Do You Yahoo!?
http://mail.yahoo.com
Try pulling out the reefing lines as if the mainsail was fully up then try to raise the main. clean and lub the sail slugs.David Grounds <drdgdo@…> wrote: I recently took my freedom 21 out and couldn’t get themain sail to go all the way up. This was not pretty.Anyways, does anybody have any suggestions as to how Ican lube the track, and is this a common thing?Dave— Nick <blueraven1@…> wrote:> Phil,> > Although I have not used it yet, I have seen many> postings which said > they used Spartite to form a collar.> > www.spartite.com > > Go to their web site and read FAQ. If you grease> the hull side of > the hole the mast will not stick to the boat if you> need to pull it
out.> > You can also ask a boat yard for a estimate to do it> for you. Pick > one that has done it before.> > Maybe a F-21 owner has used Spartite and will post a> reply.> > Nick Marino> “Blue Raven”> F-21, #295> > — In freedom21@yahoogroups.com, “Allen McClung”> <amcclung@…> > wrote:> >> > Phil,> > > > The spacer you need is a rubber thing which keeps> the mast from > > banging against the hole. I can take a digital> picture if you like > and > > put a ruler next to it. I don’t have a clue where> to tell you to go > > buy one.> > > > — In freedom21@yahoogroups.com, “knappphilip”> <filnap@> wrote:> > >> > > I have recently purchase a Freedom 21. Can some> tell me what > type
of > > > spacer or sleeve I’m to use between the free> standing CF mast and > > the > > > mast tube? I seem to be missing that item!> > > > > > Phil Knapp> > > Freedom 21> > > Port Isabel, TX.> > >> >> > > > > __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
Posted by j32080 (j32080@…>)
Use Sailkote
(http://www.888teammclube.com/frames/sailkote/index.html) on the
plastic slides. And if you can, use it in the track before you step
the mast.
I would do this at the beginning of the season. I could 'smoke" the
main when dropping it.
Also use it on the gun mount spinnaker spar and the inside of the
sleeve. See Hot Tip #4 (mine) at the site.
-John
Former F-21 owner (#259)
— In freedom21@yahoogroups.com, bill weber <billpeggyweber@…>
Dave
Posted by Nick (blueraven1@…>)
David,
Bill has it correct. If reefing lines are not fully free you won’t
be able to get the main to the top. Sailkote works.
Nick Marino
Dave
Phil,
www.spartite.com
the hull side of
need to pull it
out.
for you. Pick
reply.
Nick Marino
“Blue Raven”
F-21, #295
<amcclung@>
Phil,
the mast from
picture if you like
to tell you to go
buy one.
tell me what
type
of
Phil Knapp
Freedom 21
Port Isabel, TX.
Do You Yahoo!?
YAHOO! GROUPS LINKS
Visit your group "freedom21" on the web.
freedom21-unsubscribe@yahoogroups.com
Service.
and save big.
I am thinking about changing the reefing lines to 1/4". What do you think. I did change the reefing blocks at the mast end of the boom because some of them had frozen. Nick <blueraven1@…> wrote: David,Bill has it correct. If reefing lines are not fully free you won’t be able to get the main to the top. Sailkote works.Nick Marino— In freedom21@yahoogroups.com, bill weber <billpeggyweber@…> wrote:>> Try pulling out the reefing lines as if the mainsail was fully up then try to raise the main.> clean and lub the sail slugs.> > David Grounds <drdgdo@…> wrote:> > I recently took my freedom 21 out and couldn’t get the> main sail to go all the way
up. This was not pretty.> Anyways, does anybody have any suggestions as to how I> can lube the track, and is this a common thing?> Dave> — Nick <blueraven1@…> wrote:> > > Phil,> > > > Although I have not used it yet, I have seen many> > postings which said > > they used Spartite to form a collar.> > > > www.spartite.com > > > > Go to their web site and read FAQ. If you grease> > the hull side of > > the hole the mast will not stick to the boat if you> > need to pull it > > out.> > > > You can also ask a boat yard for a estimate to do it> > for you. Pick > > one that has done it before.> > > > Maybe a F-21 owner has used Spartite and will post a> > reply.> > > > Nick Marino> > “Blue
Raven”> > F-21, #295> > > > — In freedom21@yahoogroups.com, “Allen McClung”> > <amcclung@> > > wrote:> > >> > > Phil,> > > > > > The spacer you need is a rubber thing which keeps> > the mast from > > > banging against the hole. I can take a digital> > picture if you like > > and > > > put a ruler next to it. I don’t have a clue where> > to tell you to go > > > buy one.> > > > > > — In freedom21@yahoogroups.com, “knappphilip”> > <filnap@> wrote:> > > >> > > > I have recently purchase a Freedom 21. Can some> > tell me what > > type > > > of > > > > spacer or sleeve I’m to use between the free> > standing CF mast and > > > the > > >
mast tube? I seem to be missing that item!> > > > > > > > Phil Knapp> > > > Freedom 21> > > > Port Isabel, TX.> > > >> > >> > > > > > > > > > > > > __________________________________________________> Do You Yahoo!?> Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > > > > > ---------------------------------> YAHOO! GROUPS LINKS > > > Visit your group “freedom21” on the web.> > To unsubscribe from this group, send an email to:>
freedom21-unsubscribe@yahoogroups.com> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ---------------------------------> > > > > > ---------------------------------> New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.>
Bill,
It is your choice, ¼" will work. However, my choice is that I would
stay with 5/16" since its more line diameter to get a hold of, the
weight reduction aloft would be insignificant by going to ¼" and the
5/16" lines will run fine.
Nick Marino
Blue Raven
F21, Fin, #295
think.
