martec folding props
Posted by fgljff (esfogel@…>)
I have a martec folding prop on my Freedom 25. Anyone know how to get the thing
off?
Posted by Borelmfg (borelmfg@…>)
As with any other prop you have to use a prop puller. Most boat yards have them and will rent them out.
BTW, a hammer is not the solution.
Regards,
Van
Sent: Sunday, June 01, 2008 4:40 PM
Subject: [FreedomOwnersGroup] martec folding props
I have a martec folding prop on my Freedom 25. Anyone know how to get the thing off?
Props are secured on a tapered shaft, and are prevented from slipping
by a square (cross-section) key. After you remove the nut that holds
the prop secure, a large gear puller/ prop puller will pull the prop
of the shaft. Before replacing it, consider coating the taper and the
key with an anti-seize compound which is available at auto supply
stores. Herm
Regards,
Van
To:
<mailto:FreedomOwnersGroup@yahoogroups.com>FreedomOwnersGroup@yahoogroups.com
get the thing off?
