Posted by Randall (crawfordceramics@…>)
Very interesting! I had hesitations about buying my freedom with it’s
black round CF mast. It had so much checking on it that I had visions
of it snapping of on the first sail in a 20k wind. Well on my first
overnight in in I awoke to 20-25k gusts (apparently winds can whip up
pretty quick and with out much warning), it sustained a fairly hard
jibe (inexperienced first mate) and we popped 2 glides out midway up
the sail, and the hardwood wedges that held the mast in position in
the deck popped out, but the stick held fine, we were able to sail in
just fine.
I have questions:
1)has anyone had or heard of one these masts breaking? (under sail)
2)Can these be repaired if they are weakend or broken?
3)has anyone painted these and what type of paint would with stand
the flexing?
— In FreedomOwnersGroup@yahoogroups.com, “lance_ryley”
<lance_ryley@…> wrote:
Bright Star had some cracking in the deck and around parts of the
cockpit coaming. So does Glory. I would imagine that they are
pretty
common in Freedoms since the hulls do flex. The rigs, being
freestanding, provide no rigidity to the hull itself. Also, at
least in
the earlier Freedoms, the gel coat was put on pretty thick at
times.
This too can lead to fine cracks as the hull moves.I tend to think of ‘spiderweb’ cracks as being associated with an
impact with the gelcoat. If they are truly spiderwebs, you may want
to
check to make sure the underlying glass hasn’t been compromised.One other thing you may not be aware of are the older, black
Freedom
masts. The putty that they used to protect the outer layer was much
less flexible than the mast itself, and every one of them that I’ve
looked at has had horizontal circumferential cracks. Both surveyors
I
used on Bright Star were aware of the phenomenon, both said that as
long as the internal integrity of the fiber/resin layup hasn’t been
compromised, there was nothing much to worry about except the
cosmetics. Eric Sponberg, who oversaw much of the early mast design
construction, recommends grinding off the putty, wrapping another
layer
of glass around the mast, and finishing with awlgrip which is more
flexible. I don’t think too many people have undergone that
expense,
and it’d be hard to show conclusively one way or the other that the
horizontal cracks have ever led to mast failure. Vertical cracks,
however, are another matter entirely.Lance
— In FreedomOwnersGroup@yahoogroups.com, “Freeman Dodsworth”
<freemandodsworth@> wrote:All,
Thanks for the great response to my newbie questions. Yet
another: I
am looking at an F32 down in NC (via YW of course) and the broker
reports extensive spider cracks on deck and in the cockpit. He
further states (being a broker after all) that “every Freedom he
has
ver sold had this problem”. After I choke down the 5 pound grain
of
salt required to swallow that remark, the question remains: Is
spider
cracking a problem endemic to Freedoms? Should I expect to see a
lot
of this as I look further? Thanks again for your kind attention.Freeman
