Mast Rigging
Posted by Steve (lim@…>)
My name is Steve and I have just inherited the Freedom 21 sailboat
from my father-in-law. Will be fixing it up this summer and putting
it in the water at Galveston Bay, Texas
I’m new to sailing and new to sailing a Freedom 21. I have been
monitoring the discussions here and I am very impressed with the
sailor’s knowledge in this group.
I need some help in rigging/installing the composite mast. What do
I need in terms of hardware, etc. Also I would like to replace the
main halyards and any other lines as required.
I would compile all the information received and basically put out a
mast rigging 101.
Thanks for all the help in advance.
Happy Sailing to all.
Steve
Steve, send me your address and I will send you copies of the factory instructions for everything you need to know.My e-mail is biffsail@…Steve <lim@…> wrote: My name is Steve and I have just inherited the Freedom 21 sailboat from my father-in-law. Will be fixing it up this summer and putting it in the water at Galveston Bay, TexasI’m new to sailing and new to sailing a Freedom 21. I have been monitoring the discussions here and I am very impressed with the sailor’s
knowledge in this group.I need some help in rigging/installing the composite mast. What do I need in terms of hardware, etc. Also I would like to replace the main halyards and any other lines as required. I would compile all the information received and basically put out a mast rigging 101.Thanks for all the help in advance.Happy Sailing to all.Steve
Steve,
As starters, please go to http://www.freedom21.info./originals.htm.
Look at the following documentation.
• Commissioning Instructions - how to run the lines - (pdf)
• Factory Rigging Parts List - (pdf) Basic Spec Sheet - (pdf)
• How to Sail - (pdf)
• Line lengths / Rigging Suggestion (pdf)
• Manual
As you gain knowledge, you can ask more specific questions.
Good luck with your Freedom 21.
Nick
F-21, “Blue Raven”, Hull # 295
a
mast rigging 101.
Steve
Posted by Vivian (emmylou307@…>)
What a great inheritance! May you get her in fine shape and start enjoying soon!
Assuming the Carbon Fiber mast is out you are in a good position to check it top
to
bottom, re-wire, replace worn parts, etc.
When restepping, the connection at the keel is critical. Make sure it is bolted
well.
You can use the traditional chocks at the patners (where it passes thru the
deck) or go
with a Spartite system).
New Halyards aren’t cheap but are probably the first investment to make in
running
rigging.
See photos of Emmylou’s mast work at:
http://www.seanmulligan.com/Stories/Emmylou/
there’s another page I can’t remember…
http://www.seanmulligan.com/Stories/Deliverance/
http://www.seanmulligan.com/Stories/307FirstSail/
Spinnaker flying at: http://picasaweb.google.com/seanpmulligan/060618
Stay in touch, Sean / Vivian
Emmylou 307
BTW - we’ll be cruising all next week (on a 40’ Dufour)
Steve
Sean / Vivian,
Thanks for the links and photos of Emmylou. They are a great help.
Happy sailing to you both.
Steve Lim
enjoying soon!
to check it top to
it is bolted well.
thru the deck) or go
make in running
rigging.
Emmylou 307
Steve
