Mast sleeve?
Posted by knappphilip (filnap@…>)
I have recently purchase a Freedom 21. Can some tell me what type of
spacer or sleeve I’m to use between the free standing CF mast and the
mast tube? I seem to be missing that item!
Phil Knapp
Freedom 21
Port Isabel, TX.
Phil,
The spacer you need is a rubber thing which keeps the mast from
banging against the hole. I can take a digital picture if you like and
put a ruler next to it. I don’t have a clue where to tell you to go
buy one.
of
Phil Knapp
Freedom 21
Port Isabel, TX.
Posted by Nick (blueraven1@…>)
Phil,
Although I have not used it yet, I have seen many postings which said
they used Spartite to form a collar.
www.spartite.com
Go to their web site and read FAQ. If you grease the hull side of
the hole the mast will not stick to the boat if you need to pull it
out.
You can also ask a boat yard for a estimate to do it for you. Pick
one that has done it before.
Maybe a F-21 owner has used Spartite and will post a reply.
Nick Marino
“Blue Raven”
F-21, #295
— In freedom21@yahoogroups.com, “Allen McClung” <amcclung@…>
Phil,
buy one.
type
of
Phil Knapp
Freedom 21
Port Isabel, TX.
Posted by Joe Conron (jconron@…>)
Try rigrite.com for the Urethane Collar.
http://www.rigrite.com/Spars/SparParts/Mast_wedges.html
Urethane Mast Collar for 5 3/8" OD Round Mast: PP-F25572MC:
Special molded Urethane Mast Collar/Wedge for 5 3/8" OD Round Mast. Round
Mast Collar is 6 5/8" OD x 5 3/8" ID x 2 3/8" high and fits between the Mast
and the Deck Collar. One piece molded construction means that Mast Collar
must be put on the Mast before it is stepped. As used on Freedom 21. ***
Special Round Mast Boot to fit Freedom 21 (PP-F25443MB) is available. Hard
molded black Mast Boot fits 9" OD Round Deck Collar, and is 2 1/2" high x 5
1/2" ID.
Regards,
Joe Conron
-----Original Message-----
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On
Behalf Of Allen McClung
Sent: Saturday, March 18, 2006 8:22 AM
To: freedom21@yahoogroups.com
Subject: [freedom21] Re: Mast sleeve?
Phil,
buy one.
of
Phil Knapp
Freedom 21
Port Isabel, TX.
Yahoo! Groups Links
Posted by philip knapp (filnap@…>)
Thanks Nick, I found these guys after I posted my message.
Spars, Rigging, and Hardware for Sailboats
Rig-Rite, Inc.63 Centerville Road, Warwick, RI 02886 USAPhone: (001) 401-739-1140 – FAX: (001) 401-739-1149www.RigRite.com Ordering/Questions
Mast Wedges
Urethane Mast Collar for 5 3/8" OD Round Mast: PP-F25572MC:Special molded Urethane Mast Collar/Wedge for 5 3/8" OD Round Mast. Round Mast Collar is 6 5/8" OD x 5 3/8" ID x 2 3/8" high and fits between the Mast and the Deck Collar. One piece molded construction means that Mast Collar must be put on the Mast before it is stepped. As used on Freedom 21. *** Special Round Mast Boot to fit Freedom 21 (PP-F25443MB) is available. Hard molded black Mast Boot fits 9" OD Round Deck Collar, and is 2 1/2" high x 5 1/2" ID.
To: freedom21@yahoogroups.comFrom: blueraven1@…Date: Sun, 19 Mar 2006 23:42:07 +0000Subject: [freedom21] Re: Mast sleeve?Phil,Although I have not used it yet, I have seen many postings which said they used Spartite to form a collar.www.spartite.com Go to their web site and read FAQ. If you grease the hull side of the hole the mast will not stick to the boat if you need to pull it out.You can also ask a boat yard for a estimate to do it for you. Pick one that has done it before.Maybe a F-21 owner has used Spartite and will post a reply.Nick Marino"Blue Raven"F-21, #295— In freedom21@yahoogroups.com, “Allen McClung” <amcclung@…> wrote:>> Phil,> > The spacer you need is a rubber thing which keeps the mast from > banging against the hole. I can take a digital picture if you like and > put a ruler next to it. I don’t have a clue where to tell you to go > buy one.> > — In freedom21@yahoogroups.com, “knappphilip” <filnap@> wrote:> >> > I have recently purchase a Freedom 21. Can some tell me what type > of > > spacer or sleeve I’m to use between the free standing CF mast and > the > > mast tube? I seem to be missing that item!> > > > Phil Knapp> > Freedom 21> > Port Isabel, TX.> >>
SPONSORED LINKS
Freedom
Sailing
Boating
Sailboat
Boating magazine
Boating safety
YAHOO! GROUPS LINKS
Visit your group “freedom21” on the web.
To unsubscribe from this group, send an email to: freedom21-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Thanks Joe, I found the same web page shortly after posting my question.
To: freedom21@yahoogroups.comFrom: jconron@…Date: Sun, 19 Mar 2006 19:55:07 -0500Subject: RE: [freedom21] Re: Mast sleeve?Try rigrite.com for the Urethane Collar.http://www.rigrite.com/Spars/SparParts/Mast_wedges.htmlUrethane Mast Collar for 5 3/8" OD Round Mast: PP-F25572MC:Special molded Urethane Mast Collar/Wedge for 5 3/8" OD Round Mast. RoundMast Collar is 6 5/8" OD x 5 3/8" ID x 2 3/8" high and fits between the Mastand the Deck Collar. One piece molded construction means that Mast Collarmust be put on the Mast before it is stepped. As used on Freedom 21. ***Special Round Mast Boot to fit Freedom 21 (PP-F25443MB) is available. Hardmolded black Mast Boot fits 9" OD Round Deck Collar, and is 2 1/2" high x 51/2" ID.Regards,Joe Conron> -----Original Message-----> From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On> Behalf Of Allen McClung> Sent: Saturday, March 18, 2006 8:22 AM> To: freedom21@yahoogroups.com> Subject: [freedom21] Re: Mast sleeve?> > Phil,> > The spacer you need is a rubber thing which keeps the mast from> banging against the hole. I can take a digital picture if you like and> put a ruler next to it. I don’t have a clue where to tell you to go> buy one.> > — In freedom21@yahoogroups.com, “knappphilip” <filnap@…> wrote:> >> > I have recently purchase a Freedom 21. Can some tell me what type> of> > spacer or sleeve I’m to use between the free standing CF mast and> the> > mast tube? I seem to be missing that item!> >> > Phil Knapp> > Freedom 21> > Port Isabel, TX.> >> > > > > > > > Yahoo! Groups Links> > > > >
SPONSORED LINKS
Freedom
Sailing
Boating
Sailboat
Boating magazine
Boating safety
YAHOO! GROUPS LINKS
Posted by chris montgomery (freedom.sailingguy@…>)
Phil-- I have my mast steped at the partners with spartite. It is as
really good product and the hassle of forming the initial collar is
worth it as it will last through many steppings and unsteppings. You
just need to be sure to get it right the first time. This would be
worth getting crane help at a yard when you make the pour. Even
without a caulked seal, the spartite collar keeps most of the water
out of the bilge. You can really seal things up with a flexable
caulk. This is much less hassle than the traditional wedges and a
mast boot. Hope this helps.
Chris
of
Phil Knapp
Freedom 21
Port Isabel, TX.
Thanks for the advice!
To: freedom21@yahoogroups.comFrom: freedom.sailingguy@…Date: Sat, 25 Mar 2006 01:55:51 +0000Subject: [freedom21] Re: Mast sleeve?Phil-- I have my mast steped at the partners with spartite. It is as really good product and the hassle of forming the initial collar is worth it as it will last through many steppings and unsteppings. You just need to be sure to get it right the first time. This would be worth getting crane help at a yard when you make the pour. Even without a caulked seal, the spartite collar keeps most of the water out of the bilge. You can really seal things up with a flexable caulk. This is much less hassle than the traditional wedges and a mast boot. Hope this helps.Chris— In freedom21@yahoogroups.com, “knappphilip” <filnap@…> wrote:>> I have recently purchase a Freedom 21. Can some tell me what type of > spacer or sleeve I’m to use between the free standing CF mast and the > mast tube? I seem to be missing that item!> > Phil Knapp> Freedom 21> Port Isabel, TX.>
YAHOO! GROUPS LINKS
