Mast wiring
Hi All,
I bought a mast light for “Top Cat” and have a few questions about
wiring.
  1. I can buy 2 strand gauge marine wire for the mast for $1+ a foot
    from West Marine or I can buy three strand wire from my hardware store
    for 40 cents a foot. Is the marine wire that much better?
  2. Have you done anything to reduce the strain on the connections at
    the top of the mast? 30+ feet of wire hanging on one connecter seems
    like a lot.
Max
Hi Max,
I would definitely go for the marine grade (tinned copper) which is
more resistant to corrosion. Also you may want to use triplex if you
want provisions for a lighted Windex as seen in Blue Merle’s mast
photo. Regarding strain on the cable, try to secure to a bracket and
be sure to protect cable(s) penetrating the mast hole. Are you also
installing a VHF antenna on the mast?
Nick
F-21, #295
— In freedom21@yahoogroups.com, “Max Lent” <maxlent@…> wrote:
Hi All,
wiring.
    foot
    store
    at
    seems
    like a lot.
Max
Nick,
Yes, I have bought a new antenna for the mast. There is one already
there with a cable. I am only replacing the antenna module. Why do
you ask?
Max
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…>
Hi Max,
you
also
Nick
F-21, #295
— In freedom21@yahoogroups.com, “Max Lent” <maxlent@> wrote:
Hi All,
about
wiring.
    foot
    store
    connections
    at
    seems
    like a lot.
Max
Max,
Only that a VHF antenna bracket may also provide means to support
your light cable.
Nick
Nick,
already
do
you ask?
Max
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@>
Hi Max,
is
you
also
Nick
F-21, #295
Hi All,
about
wiring.
    foot
    hardware
    store
    connections
    at
    seems
    like a lot.
Max
Hi Nick,
How would you use the VHF antenna bracket to suppor the light cable?
Max
Max,
your light cable.
Nick
Nick,
already
do
you ask?
Max
Hi Max,
which
is
if
you
mast
bracket
also
Nick
F-21, #295
Hi All,
about
wiring.
    a
    foot
    hardware
    store
    connections
    at
    connecter
    seems
    like a lot.
Max
Hi Max,
Since I do not know what your mast configuration looks like - I can
only talk to what you might do. Look at Blue Merle’s mast photo and
there appears to be a hole to starboard of the antenna bracket and a
cable tie around both the antenna cable and the light/windex 12 vdc
cable(s). Note that her antenna cable may have a separate mast
hole. If it is practical for your cable routing, you could use one
of the bracket screws to mount a cable clamp on the bracket or do as
Blue Merle did. In any case, try to use hardware to serve multiple
tasks instead of individual tasks.
I do not know if this helps – hard to be exact without being there
and see what you have in mind for your installation.
Nick,
F21, #295
Hi Nick,
Max
Max,
your light cable.
Nick
Nick,
already
Why
do
you ask?
Max
Hi Max,
which
is
triplex
if
you
mast
bracket
you
also
Nick
F-21, #295
Hi All,
questions
about
wiring.
    $1+
    a
    foot
    hardware
    store
    connections
    at
    connecter
    seems
    like a lot.
Max
