Masthead Light-F32
Hello all, I have someone going up my mast tomorrow to replace my masthead light. What I’m wondering is, if it is a steaming light as the electrical panel switch says, an anchorlight or both? Are there 2 or 3 wires up there? I would like it to be all of the above but don’t know if that’s possible. I also wish I had bought one that was light sensative. Oh, well, I didn’t.“Life is a Reach, then you Jibe” SWARD
Posted by Borelmfg (borelmfg@…>)
Unfortunately, the boats can be wired different depending on who did the original commissioning and owner’s requirements at that time . At the base of the mast there should be a junction box for disconnecting the wires so the mast can be pulled. At the box you should be able to tell what you have. A volt/ohm meter will help in figuring it all out.
regards,
van
To: freedomyachts2003@… ; FreedomOwnersGroup@yahoogroups.com
Sent: Saturday, April 05, 2008 9:20 AM
Subject: [FreedomOwnersGroup] Masthead Light-F32
Hello all,
SWARD
You can have it any way you want depending
on what you replace it with. I believe even with 2 wires it is possible to have
both, they make some that by reversing polarity the switch is able to change
modes. At least I think I recall this.
Alan F-33 Hull #51 1982 SEAPR
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward
1:21 PM
To: freedomyachts2003@…; FreedomOwnersGroup@yahoogroups.com
Masthead Light-F32
Hello all,
I have
Jibe”
SWARD
Thank you-I hadn’t thought about that junction boxBorelmfg <borelmfg@…> wrote: Unfortunately, the boats can be wired different depending on who did the original commissioning and owner’s requirements at that time . At the base of the mast there should be a junction box for disconnecting the wires so
the mast can be pulled. At the box you should be able to tell what you have. A volt/ohm meter will help in figuring it all out. regards, van ----- Original Message ----- From: Sward To: freedomyachts2003@yahoo.com ; FreedomOwnersGroup@yahoogroups.com Sent: Saturday, April 05, 2008 9:20 AM Subject: [FreedomOwnersGroup] Masthead Light-F32 Hello all, I have someone going up my mast tomorrow to replace my masthead light. What I’m wondering is, if it is a steaming light as the electrical panel switch says, an anchorlight or both? Are there 2 or 3 wires up there? I would like it to be all of the above but don’t know if that’s possible. I also wish I had bought one that was light sensative. Oh, well, I didn’t. “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
