Posted by reedjayt2004 (reedjayt@…>)
This last spring I replaced the strut bearing on my 1994 Freedom 35.
Since the prop needed to be removed, I took the opportunity to have it
serviced. ( They cleaned and regreased all the internal parts,instead
of just topping off the grease in the zerts) On a couple of trips
this spring, it seemed fine, but last weekend, I couldn’t get the
engine above 2,000 RMP and the speed seemed to be a lower than normal
speed over water.
I was wondering if anyone else has a MAX prop on a Freedom and knows
the settings they are using.
Jay
Posted by f35sail (s.goward@…>)
Jay:
Big problems with prop barncles in Cheaspeake this spring. Our 2
blade could only get to 5 knots until we had a good hard sail. Friend
with Maxprop on Cal 39 overheated.
S.G.
— In freedomyachts2003@yahoogroups.com, “reedjayt2004”
speed over water.
Jay
Posted by Jay T. Reed (reedjayt@…>)
Thanks Fred. I’m thinking that may also be my problem. I’ve notice more
growth on my knotmeter paddle wheel since I moved the boat from the
Sassafrass down to Rock Hall.
Reply-To: freedomyachts2003@yahoogroups.com
Subject: Re: [freedomyachts2003] MAX Prop on a Freedom 35
Date: Wed, 26 Jul 2006 15:24:09 -0400
Hi Jay, I had a similar problem after the boat (F35) sat for a while. I
couldn’t get the RPM up and boat speed was low for the RPM’s I could get.
The problem was barnacles on the prop surface and in the gears of the max
prop. The prop would not fully deploy and when it did it was not
efficient. A bit of scraping and holding of breath and all was well.
Fred
Sent: Monday, June 26, 2006 2:55 PM
Subject: [freedomyachts2003] MAX Prop on a Freedom 35
speed over water.
Jay
Posted by Jeff Chale (jwchale@…>)
If you are looking for the setting on the Max prop, call PYI. They will have a record of the original owner and the setting, and if you don’t know the name of the person purchasing the prop, tell them you have a 199x Freedom 35 with a 3GM30F and they will be able to look up the boat and the suggested setting. Jeff"Jay T. Reed" <reedjayt@…> wrote: Thanks Fred. I’m thinking that may also be my problem. I’ve notice more growth on my knotmeter paddle wheel since I moved the boat from the Sassafrass down to Rock
Hall.>From: “Fred Molden” <fredmolden@comcast.net>>Reply-To: freedomyachts2003@yahoogroups.com>To: <freedomyachts2003@yahoogroups.com>>Subject: Re: [freedomyachts2003] MAX Prop on a Freedom 35>Date: Wed, 26 Jul 2006 15:24:09 -0400>>Hi Jay, I had a similar problem after the boat (F35) sat for a while. I >couldn’t get the RPM up and boat speed was low for the RPM’s I could get. >The problem was barnacles on the prop surface and in the gears of the max >prop. The prop would not fully deploy and when it did it was not >efficient. A bit of scraping and holding of breath and all was well.>Fred> ----- Original Message -----> From: reedjayt2004> To: freedomyachts2003@yahoogroups.com> Sent: Monday, June 26, 2006 2:55 PM> Subject: [freedomyachts2003] MAX Prop on a Freedom 35>>> This last spring I replaced the strut bearing on my 1994 Freedom 35.> Since the prop needed to be removed, I took the opportunity to have it> serviced. ( They cleaned and regreased all the internal parts,instead> of just topping off the grease in the zerts) On a couple of trips> this spring, it seemed fine, but last weekend, I couldn’t get the> engine above 2,000 RMP and the speed seemed to be a lower than normal> speed over water.>> I was wondering if anyone else has a MAX prop on a Freedom and knows> the settings they are using.>> Thanks> Jay>>>>
Do you Yahoo!? Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
Posted by Fred Molden (fredmolden@…>)
Hi Jay, I had a similar problem after the boat (F35) sat for a while. I couldn’t get the RPM up and boat speed was low for the RPM’s I could get. The problem was barnacles on the prop surface and in the gears of the max prop. The prop would not fully deploy and when it did it was not efficient. A bit of scraping and holding of breath and all was well.
Fred
This last spring I replaced the strut bearing on my 1994 Freedom 35. Since the prop needed to be removed, I took the opportunity to have it serviced. ( They cleaned and regreased all the internal parts,instead of just topping off the grease in the zerts) On a couple of trips this spring, it seemed fine, but last weekend, I couldn’t get the engine above 2,000 RMP and the speed seemed to be a lower than normal speed over water.I was wondering if anyone else has a MAX prop on a Freedom and knows the settings they are using.ThanksJay
