Max Prop
For what its worth… RH 3 blade, 17 dia. max prop, 2.61 reduction
gear 27 hp, I use 18* or 10.4" of pitch and turn within 100 of my
target RPM.
Posted by swardfullsail (swardfullsail@…>)
Do you think the Max Prop can be taken off the shaft underwater by a
diver and worked on out of the water and put back on in the water?
It’s either that or get some hang time on a lift to fix the pitch. I
don’t need to haul the boat as I am heading south in a week or so and
had the boat hauled in the spring.
Sward
PYI installation instructions advise that the max prop be disassembled
down to the core spinner before removal or installation. There are too
many small critical parts. Hang time in a lift or a short haul is the
prefered method. I’ve removed and repitched mine and it takes some
practice and 3 hands.
— In freedomyachts2003@yahoogroups.com, “swardfullsail”
I
Sward
That’s what it looked like in the book that came with it. The rpm’s should be 3400 and I’m getting 2800. How much pitch increase would you recommend. Would it be one or two increments?macks011 <macks04@…> wrote:
PYI installation instructions advise that the max prop be disassembled down to the core spinner before removal or installation. There are too many small critical parts. Hang time in a lift or a short haul is the prefered method. I’ve removed and repitched mine and it takes some practice and 3 hands.— In freedomyachts2003@yahoogroups.com, “swardfullsail” <swardfullsail@y…> wrote:>> Do you think the Max Prop can be taken off the shaft underwater by a > diver and worked on out of the water and put back on in the water? > > It’s either that or get some hang time on a lift to fix the pitch. I > don’t need to haul the boat as I am heading south in a week or so and > had the boat hauled in the spring.> > Sward>
YAHOO! GROUPS LINKS
Visit your group “freedomyachts2003” on the web.
To unsubscribe from this group, send an email to: freedomyachts2003-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Pitch DECREASE
Sent: Saturday, October 22, 2005 5:53 PM
Subject: Re: [freedomyachts2003] Re: Max Prop
That’s what it looked like in the book that came with it. The rpm’s should be 3400 and I’m getting 2800. How much pitch increase would you recommend. Would it be one or two increments?macks011 <macks04@…> wrote: PYI installation instructions advise that the max prop be disassembled down to the core spinner before removal or installation. There are too many small critical parts. Hang time in a lift or a short haul is the prefered method. I’ve removed and repitched mine and it takes some practice and 3 hands.— In freedomyachts2003@yahoogroups.com, “swardfullsail” <swardfullsail@y…> wrote:>> Do you think the Max Prop can be taken off the shaft underwater by a > diver and worked on out of the water and put back on in the water? > > It’s either that or get some hang time on a lift to fix the pitch. I > don’t need to haul the boat as I am heading south in a week or so and > had the boat hauled in the spring.> > Sward>
YAHOO! GROUPS LINKS
THANK YOU!!!Jerome Weinraub <zayde@…> wrote:
Pitch DECREASE
YAHOO! GROUPS LINKS
Check the message thread starting with #4728. Thats a 600 RPM gap
which would require between 4 to 8 inches of pitch decrease. check
the Max prop chart to find the closest correlation between inches
and their degree settings. I would decrease the pitch by 4 degrees
on the first attempt and see how close I came to the target.If I was
more than 200RPM short, I’d decrease pitch by another setting. If
you are underpropped or overpropped by 100 RPM, its close enough.
— In freedomyachts2003@yahoogroups.com, Sward <swardfullsail@y…>
macks011 <macks04@o…> wrote:PYI installation instructions advise
too
by a
water?
pitch.
I
so
Sward
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003" on the web.
Service.
If your engine is a 3GM30F, It can be equipped with one of three transmission ratios; 2.36, 2.61, or 3.22 : 1. It is probably 2.61 : 1, most are. You can verify that by locating the plaque on either the side of the trans, or the back of the bell housing (that’s where mine is) If that is correct, and you have a three blade 14 in. diameter prop, you should probably set your prop according to line “L” on the chart. That will give you 28 deg blade angle, and 13.9 inches of pitch. If your engine is running “up to snuff”, you should have no problem getting very close to your required(?) 3600rpm. Also, you should really do this by completely dis-assembling the prop so as to start from scratch and be really certain that you have the correct X’s and Y’s.
YAHOO! GROUPS LINKS
Yahoo! FareChase - Search multiple travel sites in one click.
Pual,
Wouldn’t that INCREASE the prop from 11.8 to 13.9? How important is this to do now? I’m realizing I’m creating another project when I can least afford it. I’m late leaving Baltimore and need to get to Marathon, if it’s still there in about a month. I think I will have to find crew to help me go offshore to get this accomplished. Any volunteers?
I have had surgery and still can’t leave-at least a 3 week delay as had been expected and still trying to get rid of an iinfection.
YAHOO! GROUPS LINKS
Sward,
Yes, a setting of 24 deg. blade angle (11.8 in. pitch) would be a finer (flatter) pitch than 28 deg.blade angle/13.9 in. prop pitch. If in fact your prop is really set @ 24 deg/11.8 pitch and you can’t get any more than 2800 rpm, I suspect you might have other problems. I base this premise on the fact that I presently run a 14" three blade michigan fixed pitch prop with a 14" pitch (it’s stamped right on the prop). If you quantify a standard fixed pitch prop as being 100% eficient, then a MaxProp of the same size/diameter is 97% efficient by PYI’s own admission. This applies to running forward only. A MaxProp is light years more efficient in reverse.
Hope this helps.
By the way, does your engine overheat underway @ 2800rpm?
PWM
PS, Wrong coast to crew for you…P
Pual,
YAHOO! GROUPS LINKS
A three blade is always more efficient, esp in reverse.
Posted by Bob Frew (rfrew@…>)
Last year I looked at Autoprop and found out that I
did not have enough clearance. this year I called Max
prop and they will sell me a 14" 3 blade for 2240.
They said that the 3gm was probeably not the original
engine. was too much power for a 14 2 blade and the 3
blade would work much better. Does anyone have an
opinion on this.
thanks, Bob Frew, Freespirit, Freedom 32.
Bob, If you can send me the reduction ratio stamped on the I.D.plate of your reduction gear I may be able to help. It seems to me that the diameter of your prop is much to small for the engine you have . In broad and general terms, diameter is what gives you push and stopping power. Blade area is capital here. Pitch gives speed. Send also h.p. and max RPM indicated on engine i.d. plate. Weight of vessel and sailing water line length would nail it down.16 in. whether 2 or 3 blade is probably correct. Pitch would also vary vary depending on what you send. Andre. Bob Frew <rfrew@…> wrote: Last year I looked at Autoprop and found out that Idid not have enough clearance. this year I called Maxprop and they will sell me
a 14" 3 blade for 2240.They said that the 3gm was probeably not the originalengine. was too much power for a 14 2 blade and the 3blade would work much better. Does anyone have anopinion on this.thanks, Bob Frew, Freespirit, Freedom 32.
Dear Andre,
The ratio is 2.62:1. The problem is the clearance
which is 1".
Thanks, Bob
— andre laviolette <andrelaviolette@…> wrote:
Bob,
send.
Andre.
I
Max
original
3
opinion on this.
SPONSORED LINKS
Sailing schools Sailing instruction
Sailing lesson Sailing course Sailing
adventure Sailing
YAHOO! GROUPS LINKS
to:
Bob, Can the hull be ground away and even reglassed. I have done this in the past when I changed from a folding to a solid prop. for cruising a race boat. Do you have a deadwood ( aperture ) clearance or hull clearance problem ? Andre.Bob Frew <rfrew@…> wrote: Dear Andre,The ratio is 2.62:1. The problem is the clearancewhich is 1". Thanks, Bob— andre laviolette <andrelaviolette@…> wrote:> Bob,> > If you can send me the reduction ratio stamped on> the I.D.plate of your reduction gear I may be able> to help. It seems to me that the diameter of your> prop is much to small for the engine you have . In> broad and general terms,
diameter is what gives you> push and stopping power. Blade area is capital here.> Pitch gives speed. Send also h.p. and max RPM> indicated on engine i.d. plate. Weight of vessel and> sailing water line length would nail it down.> 16 in. whether 2 or 3 blade is probably correct.> Pitch would also vary vary depending on what you> send.> > Andre.> > > Bob Frew <rfrew@…> wrote:> Last year I looked at Autoprop and found out that> I> did not have enough clearance. this year I called> Max> prop and they will sell me a 14" 3 blade for 2240.> They said that the 3gm was probeably not the> original> engine. was too much power for a 14 2 blade and the> 3> blade would work much better. Does anyone have an> opinion on this.> > thanks,
Bob Frew, Freespirit, Freedom 32.> > > SPONSORED LINKS > Sailing schools Sailing instruction > Sailing lesson Sailing course Sailing> adventure Sailing > > ---------------------------------> YAHOO! GROUPS LINKS > > > Visit your group “freedomyachts2003” on the web.> > To unsubscribe from this group, send an email> to:> freedomyachts2003-unsubscribe@yahoogroups.com> > Your use of Yahoo! Groups is subject to the> Yahoo! Terms of Service. > > > --------------------------------->
        > ---------------------------------> Find your next car at Yahoo! Canada Autos
Bob, Another solution is a longer shaft but to maintain correct distance between strut and prop. you would have to install a longer strut positioned further aft. Difficult in some cases therefore labour expensive. On my one tonner ( a little heavier than your 32 and simillar engine HP and propeller Rpm ) I was able to thin down hull above prop. to an acceptable thicness ( it was 1 1/2 In. thick ) and went to a square three blade prop.with a 60% blade to disc area. 14 " X 14 " . Not the best but it worked for the 6 mo. Bahama trip. Andre.Bob Frew <rfrew@…> wrote: Dear Andre,The ratio is 2.62:1. The problem is the clearancewhich is 1". Thanks, Bob— andre
laviolette <andrelaviolette@…> wrote:> Bob,> > If you can send me the reduction ratio stamped on> the I.D.plate of your reduction gear I may be able> to help. It seems to me that the diameter of your> prop is much to small for the engine you have . In> broad and general terms, diameter is what gives you> push and stopping power. Blade area is capital here.> Pitch gives speed. Send also h.p. and max RPM> indicated on engine i.d. plate. Weight of vessel and> sailing water line length would nail it down.> 16 in. whether 2 or 3 blade is probably correct.> Pitch would also vary vary depending on what you> send.> > Andre.> > > Bob Frew <rfrew@…> wrote:> Last year I looked at Autoprop and found out that>
I> did not have enough clearance. this year I called> Max> prop and they will sell me a 14" 3 blade for 2240.> They said that the 3gm was probeably not the> original> engine. was too much power for a 14 2 blade and the> 3> blade would work much better. Does anyone have an> opinion on this.> > thanks, Bob Frew, Freespirit, Freedom 32.> > > SPONSORED LINKS > Sailing schools Sailing instruction > Sailing lesson Sailing course Sailing> adventure Sailing > > ---------------------------------> YAHOO! GROUPS LINKS > > > Visit your group “freedomyachts2003” on the web.>
To unsubscribe from this group, send an email> to:>  <freedomyachts2003-unsubscribe@yahoogroups.com>>     >     Your use of Yahoo! Groups is subject to the> Yahoo! Terms of Service. > >     > --------------------------------->   > > > >             > ---------------------------------> Find your next car at Yahoo! Canada Autos
I have an F-33 and found the Variprop has
a very short hub. They can provide 3 or even 4 bladed and it has a number of
other benefits. They also do custom sizes so the do 15.5” instead of 15
or 16 which are standard sizes (no real cost difference). I played with the
pitch a bit although their calculations were usable. If you mention F-33 to Michael
804-436-0150 www.varipropusa.com fax 804-436-0140 and my name he’ll be
able to look up all the specifications on mine although your 32 would be a bit
different)
I’ve been very happy with it and
have had it for several years.
Alan Kusinitz F-33 Hull #51 1982
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of andre laviolette
Sent: Sunday, February 19, 2006
9:30 AM
To:
Max Prop
Bob,
down.
Andre.
Bob Frew
Max
2240.
original
the 3
opinion on this.
Autos
it’s a hull clearance problem
Bob,
Andre.
Dear Andre,
which is 1".
Thanks, Bob
Bob,
on
able
you
here.
send.
Andre.
that
I
Max
original
3
opinion on this.
SPONSORED LINKS
adventure Sailing
YAHOO! GROUPS LINKS
web.
to:
SPONSORED LINKS
adventure Sailing
YAHOO! GROUPS LINKS
to:
If you really needed the area and normal
hull clearance to minimize turbulence you could go to a smaller but 4 bladed
prop. I considerd that for my F-33 but decided I could live with a 15.5”.
Not sure which manufacturers offer that I remember Variprop did. If I remember
correctly it was about 25% more in cost for 4 bladed but my memory may be off.
Alan
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Bob Frew
10:22 AM
To:
Max Prop
problem
Bob,
even reglassed. I
from a
boat.
or
Andre.
Dear Andre,
clearance
which is 1".
Thanks, Bob
— andre laviolette
<andrelaviolette@…>
Bob,
on
gear I may be
able
diameter of your
have . In
what gives
you
capital
here.
max RPM
of vessel
down.
correct.
what you
send.
Andre.
that
I
I called
Max
blade for 2240.
original
blade and
3
anyone have an
opinion on this.
Freedom 32.
SPONSORED LINKS
    Sailing
Sailing lesson
adventure Sailing
YAHOO! GROUPS LINKS
Visit your group
web.
To unsubscribe
to:
Your use of
Autos
SPONSORED LINKS
Sailing lesson
adventure Sailing
YAHOO! GROUPS LINKS
Visit your group
To unsubscribe from
to:
Your use of Yahoo!
Bob, All in all, you could opt for a used 3 blade power boat prop. and save $ 2000.00 It will slow you down 1/2 + knot or so in light to moderate winds over a folder however. Andre.Bob Frew <rfrew@…> wrote: Last year I looked at Autoprop and found out that Idid not have enough clearance. this year I called Maxprop and they will sell me a 14" 3 blade for 2240.They said that the 3gm was probeably not the originalengine. was too much power for a 14 2 blade and the 3blade would work much better. Does anyone have anopinion on this.thanks, Bob Frew, Freespirit, Freedom 32.
