Monel pop rivets
Hello all! Does anyone have 12 or more monel pop rivets that I can buy,
to replace the rivets on my F25 gooseneck?? Yes, I did tear the
gooseneck off of the mast, with an involuntary jibe in 45++ winds.
Thanks. Charlie
I have some stainless pop rivets. I’d have to check the size, but I bought them to replace a few loose ones on my mast track (needed 6 and had to buy 100).
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Charlie L.Sent: Thursday, June 29, 2006 12:24 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Monel pop rivets
Hello all! Does anyone have 12 or more monel pop rivets that I can buy, to replace the rivets on my F25 gooseneck?? Yes, I did tear the gooseneck off of the mast, with an involuntary jibe in 45++ winds. Thanks. Charlie
Although I don’t exactly recall the explanation, Mark Edwards or
Dave Wolfe cautioned me many years ago about using rivets other than
aluminum for the mast track. I think the concern was that if a ss
rivet loses grip it will create a larger hole forcing you to use a
larger rivet. Again I can’t rememeber the conversation but I do know
that Freedom Yachts recommended aluminum.
I
had to buy 100).
Al Lorman
F30 Ab Initio
buy,
Thanks. Charlie
I have some of them, too. Bought both kinds, 100 per box.
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Dave_BenjaminSent: Friday, June 30, 2006 1:52 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Monel pop rivets
Although I don’t exactly recall the explanation, Mark Edwards or Dave Wolfe cautioned me many years ago about using rivets other than aluminum for the mast track. I think the concern was that if a ss rivet loses grip it will create a larger hole forcing you to use a larger rivet. Again I can’t rememeber the conversation but I do know that Freedom Yachts recommended aluminum.— In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” <ajlorman@…> wrote:>> I have some stainless pop rivets. I’d have to check the size, but I> bought them to replace a few loose ones on my mast track (needed 6 and> had to buy 100).> > > Al Lorman> F30 Ab Initio> -----Original Message-----> From: freedomyachts2003@yahoogroups.com> [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Charlie L.> Sent: Thursday, June 29, 2006 12:24 PM> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Monel pop rivets> > > > Hello all! Does anyone have 12 or more monel pop rivets that I can buy, > to replace the rivets on my F25 gooseneck?? Yes, I did tear the > gooseneck off of the mast, with an involuntary jibe in 45++ winds. > Thanks. Charlie> > > > > > IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisor> > This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.>
