Hi everyone, we just acquired a 1983 Freedom 25 with rotating mast. The mainsail is the original, 40 years old, with 6 full carbon fiber sandwich battens plus one along the foot. I’ve started enquiring at local sail lofts in Rhode Island where the boat is, and the modern design proposals are so different than the original, that it has me nervous.
Examples in proposals I’ve received:
- 4 battens, not 6 (not including the batten in the foot)
- No batten in the foot, where the original has one.
- Because of 4 not 6, the batten locations are not exactly at the reef points as they were before, which I really liked for reefing.
- May not be able to reuse the carbon fiber sandwich battens which are very robust.
Questions:
- I would like to hear any experiences you’ve had in Freedom 25 mainsail replacement (or from adjacent models). Did you replace in kind, matching the old design, or have you gone with something more modern, and what were the +/-?
- Did any of you move the old carbon fiber battens to a new sail? How did that work out?
- Should I be concerned with going from 7 battens to 4, and not having one on the foot, with modern materials and design?
- Is there anything special about the rotating mast that I should consider that would influence sail design?
- Any advice appreciated.
Quotes have been in the ~$2900 - 4500 range for base dacron and the next step up engineered dacron/taffetta, w/ 4 battens. I’m sure more expensive with custom /replacing in kind.
Some photos of the original mainsail are attached.
Thanks, Robert
