I have a Perkins 4.108 with a Sherwood G-65 raw water pump. I just
rebuilt the pump because it was badly leaking. The seal was
compressed sideways because the bearings were done. Fortunately no
water had entered the engine along the drive shaft of the pump.
I ordered a rebuild kit in the US, couldn’t find one on stock here in
Europe.
It wasn’t easy to get the two ball bearings off the shaft without the
proper tools; I damaged the shaft end a bit and had to grind it in
shape again. Inside the pump is a half moon between inlet and outlet
called ‘cam’. What struck me as odd is the fact that the cam is
screwed to the inside of the body through a too large hole without
seal. On the pump drawing they suggest to seal it with epoxy or
locktite (they use the brand name Permatex). Not a real nice
engineering solution, I feel, but with instantly curing thick epoxy
it seems to work.
What I noticed for the first time, is that the pump is mounted upside
down against the Perkins block. The cam in the pump body is usually
on top, here it’s at the bottom of the pump. The cam screw is
therefore also on the bottom and cannot be used as a bleeder for the
pump. Yes you need to bleed this pump, which I’ve never heard before.
Perhaps that’s because the inlet and outlet are at the bottom of the
pump body too, therefore air gets trapped in the upper part of the
pump. The only way to bleed it is to loosen all four screws on the
front plate, start the engine (water gushing around all over the
engine room) and then tighten the screws, the top one last. Only
after doing this, I got water out of the exhaust.
