Prop for Freedom 30
Not sure how it happened but one blade of the two blade Martec prop is bent on our Freedom 30 (#66), named Trio. I have the following boat specs that I’ve entered into the vicprop.com prop size calculation tool although I am unsure of the waterline length, the hull draft excluding keel, the max rpm, and the number of shaft bearings.
Regardless of these details, does anyone have words of wisdom for purchasing a replacement prop for this F30?
Thanks for any input!
|Waterline length in feet:|25 feet|
|Beam at the waterline in feet:|10.7 feet|
|Hull draft in feet (excluding keel):|4.7 feet|
|Vessel weight in pounds:|7660 lbs|
|Engine Horsepower:|18 HP|
|Number of engines:|1|
|Total Engine Horsepower:|18 HP|
|Engine R.P.M. (max):|3500 RPM|
|Gear Ratio:|2.62:1|
|Shaft R.P.M. (max):|1336 RPM|
|Number of shaft bearings (per shaft):|4|
|Desired speed in Knots:|7 knots|
Shaft diameter: 1"
i just replaced the prop of my F30 a couple months ago if you still need info
Hi, I am new to this board and also have a F30 based in South Portland, ME. I’m not so much reaching out on the topic but more so to connect. Thank you.
