Posted by merrick white (r__merrick_white@…>)
I have one horizontal 6 lb alum propane tank; but, need a backup. Does
anyone know where to purchase one? A Google search has come up dry.
Posted by Borelmfg (borelmfg@…>)
Try ww.go2marine.com. Search “propane” Note: a Horz is about 50% that the same size vert.
Regards,
Van
Sent: Sunday, June 29, 2008 9:43 AM
Subject: [FreedomOwnersGroup] Propane tank
I have one horizontal 6 lb alum propane tank; but, need a backup. Does anyone know where to purchase one? A Google search has come up dry.
Thanks Van, but they only have the 6lb vertical. The F32 lockers
can’t hold anything bigger.
— In FreedomOwnersGroup@yahoogroups.com, “Borelmfg” <borelmfg@…>
that the same size vert.Regards,
Van
Subject: [FreedomOwnersGroup] Propane tankI have one horizontal 6 lb alum propane tank; but, need a backup.
Does
dry.
One thing I have considered using is disposable 1 lb propane cyls. You can buy them for about $2 ea in pks of 6 at Cosco. You can buy a propane disp. bottle adapter to regualtor (G-488P) from Marshall brass. May cost more per lb of propane, but figuring the cost of a propane tank, you can buy a lot of propane even at the higher cost/lb. And, if there is a leak, the most that will leak is 1 lb. I use to store the spares in a PVC tube mouting on the stern rail. No propane below decks. Also no need to lug tanks for refill.
Best of luck.
Van
Sent: Sunday, June 29, 2008 1:41 PM
Subject: [FreedomOwnersGroup] Re: Propane tank
Thanks Van, but they only have the 6lb vertical. The F32 lockers can’t hold anything bigger.— In FreedomOwnersGroup@yahoogroups.com, “Borelmfg” <borelmfg@…> wrote:>> Try ww.go2marine.com. Search “propane” Note: a Horz is about 50% that the same size vert.> > Regards,> > Van> ----- Original Message ----- > From: merrick white > To: FreedomOwnersGroup@yahoogroups.com > Sent: Sunday, June 29, 2008 9:43 AM> Subject: [FreedomOwnersGroup] Propane tank> > > I have one horizontal 6 lb alum propane tank; but, need a backup. Does > anyone know where to purchase one? A Google search has come up dry.>
Defender and West Marine (West Bucks) has
aluminum ones but are expensive, $140. These I know fit in the
F35s. I have a 5 lb tank and will have two for my F30, these are
what the contractor use for the plumbing torches. http://domsoutdoor.com/product.asp?pn=1-026658
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of merrick
white
Sent: Sunday, June 29, 2008 12:44
PM
To:
Propane tank
need a backup. Does
Posted by mariemarine19 (mariemarine19@…>)
I was able to purchase a Worthington (same as original) 6 lb. cylinder through
my local
propane distributor who fitted a horizontal valve on it.
Bill
— In FreedomOwnersGroup@yahoogroups.com, “mariemarine19”
cylinder through my local
propane distributor who fitted a horizontal valve on it.Bill
COOL! Could you give me contact information for your local distributor?
I’ve looked everywhere, I’ve even called Worthington themselves. No
luck. I have an extra tank with a bad valve and my local guys take one
look at it, they say there is no horizontal valve available for it and
they send me packing. If I could just get the valve itself from your
guy I could have a spare tank again!
Rick
Tallahassee
— In FreedomOwnersGroup@yahoogroups.com, “merrick white”
Does
Check Hamilton Marine as well - they have some horizontals, just don’t
know if they’re the right size.
Rick,
I went to a propane company that sells and fills large “pigs” for home heating,
cooking, etc.,
before OPD valves were required on horizontal tanks. I checked with the local
guy who said
they have OPD valves for horizontal tanks now, but he doesn’t carry them, sorry.
IHe suggest
trying a larger propane supplier.
