Propeller Size for 88 Freedom 45''
Posted by m0mzi11a (m0mzilla@…>)
During our sea trial we could only achieve 2800rpms at max throutle
from the 66HP yanmar turbo. It should achive 3600 RPMs. The engine
runs great and does not smoke. It only has 2050 hrs on engine. The
boat achived 8.9 Knots but only 2800rpms. I took the turbo off to
have checked out. The mechanic suggested that I make sure that I am
not over propped for our configuration. I too beleive that the boat
may have too much prop. Any owners out there with a 66HP Yanmar on
your 45’ boat and can achive rated rpms with your prop. Could you let
me know what prop you have installed on you freedom. Thank you so
much.
Bill and Julia
Posted by Robert (robert@…>)
Bill/Julia
You are making well over ‘Hull Speed’ which I calculated at just under 8 knots based on a waterline lenght of 34’ 5" therefore I would say you are definitely ‘over-propped’. This is nothing unusual as I have noted that many Freedoms are spec’d with props which are over pitched. My F32 has an original 2 bladed 14x14 prop and the engine only rev’s to 3,000RPM. My calculations tell me I need a 14x11 prop - That’ll be a job for the next haul-out.
Let me know what the propeller diameter is for the F45 and I will calculate the prop pitch required. BTW: Do you know what size propeller is already fitted?
Robert
Posted by Al Lorman (ajl@…>)
Are
you sure that the tach is accurate? I just bought a boat with a Yanmar
and the surveyor found that the tach was running 500 rpm too low.
Al
Behalf Of m0mzi11a
Sent: Sunday, December 07, 2008 3:29 PM
Subject: [FreedomOwnersGroup] Propeller Size for 88 Freedom 45’
much.
Bill and Julia
Not sure but I believe that the surveyer during my sea trial checked
the egine RPM and temp with his own gagues.
— In FreedomOwnersGroup@yahoogroups.com, “Al Lorman” <ajl@…>
Are you sure that the tach is accurate? I just bought a boat with
a Yanmar
Al
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of m0mzi11a
throutle
am
boat
let
much.
Bill and Julia
I have an 18X12 prop currently. I appreciate your time and help.
Bill and Julia
— In FreedomOwnersGroup@yahoogroups.com, “Robert” <robert@…>
Bill/Julia
under 8
you are
noted that
F32 has an
3,000RPM. My
the next
haul-out.
calculate
already
fitted?
Robert
— In FreedomOwnersGroup@yahoogroups.com, “Robert” <robert@…> wrote:
Bill/Julia
8
are
that
an
next
haul-out.
calculate
already
fitted?
Robert
Robert our current prop is a 18X12. Thankyou for your help
Julia and Bill
Posted by rfurborough (robert@…>)
Sorry, should have asked before, I also need to know the transmission
gear ratio.
Robert
— In FreedomOwnersGroup@yahoogroups.com, “m0mzi11a” <m0mzilla@…>
Bill and Julia
