I’ve spent the last few weekends getting my Freedom, soon to be
christended the Maccochaque II (pronounced Mack-A-Jack. Maccochaque is
a Shawnee Indian word that means “place of refreshment.” It also
happens to be the name of the grade school where my father and his
siblings attended.) ready for paint. I was looking at the mast and now
have the following questions:
What experience have any of you had drilling holes in the mast to
accommodate electrical wiring (mast light)?
What do you use to cap the mast to keep the elements (snow/rain/bird
droppings/squirrel nests) from running down the inside of the hollow
mast tube and accumulating in the cabin?
Posted by j32080@…> (j32080@…>)
Both questions have had numerous answers and responses. Search the forum. Re: drilling the carbon fiber mast. I wired “Blue Merle” with a mast light. See the Freedom21.info site for detailed pictures. I drilled a hole at the base of the mast to handle the 1/2" 4 conductor wire. As for a cap, some owners have used a PVC “plug” that is often used for waste pipe. Availabe at your local home improvement store. I was fortunate to still have the original soft plastic cap for “Blue Merle”. Also seen at the Freedom21.info site. -John Doug Chace <ch47_av8r@…> wrote: I’ve spent the last few weekends getting my Freedom, soon to be christended the Maccochaque II (pronounced Mack-A-Jack. Maccochaque is a Shawnee Indian word that means “place of refreshment.” It also happens to be the name of the grade school where my father and his siblings attended.) ready for paint. I was looking at the mast and now have the following questions:What experience have any of you had drilling holes in the mast to accommodate electrical wiring (mast light)?What do you use to cap the mast to keep the elements (snow/rain/bird droppings/squirrel nests) from running down the inside of the hollow mast tube and accumulating in the cabin?Thanks,Doug
Everyone is raving about the all-new Yahoo! Mail beta.
Doug great question I myself am about to do the same
exact work on my carbon fibor mast. I hope some one
has an answer for us.
Chrlie
soon to be
father and his
at the mast and now
in the mast to
(snow/rain/bird
I have capped my mast with a plastic cap that has built in
compression springs. Go to http://www.mcmaster.com/ and look on page
3631. I do not recall which size Thermoplastic cap I used, but I
imagine it is the 3.5" or 4". I then sealed it with a UV resistent
sealant.
Chrlie
soon to be
father and his
at the mast and now
in the mast to
(snow/rain/bird
Doug/Charie: Take a look at this photo: http://www.seanmulligan.com/Stories/Deliverance/target16.html I drilled new nole with a cordless drill and regular drill bit. I drilled a little smaller than the diameter of the threads. The stainless steel panhead screws are self-tapping. The open end is covered with rubber membrane roofers use. Our sail loft gave it to us. A band clamp holds it in place. I covered the bandclamp with black PVC tape. I had to make sure the wind indicator cleared the antenae. After PVC tape I applied liquid electrical tape as well. White silicone caulk fills hole where wires penetrate. Let us know what you come up with. Seancharles
dzwonkowski <cskidwain@…> wrote: Doug great question I myself am about to do the sameexact work on my carbon fibor mast. I hope some onehas an answer for us.Chrlie— Doug Chace <ch47_av8r@yahoo.com> wrote:> I’ve spent the last few weekends getting my Freedom,> soon to be > christended the Maccochaque II (pronounced> Mack-A-Jack. Maccochaque is > a Shawnee Indian word that means “place of> refreshment.” It
also > happens to be the name of the grade school where my> father and his > siblings attended.) ready for paint. I was looking> at the mast and now > have the following questions:> > What experience have any of you had drilling holes> in the mast to > accommodate electrical wiring (mast light)?> > What do you use to cap the mast to keep the elements> (snow/rain/bird > droppings/squirrel nests) from running down the> inside of the hollow > mast tube and accumulating in the cabin?> > Thanks,> Doug> > __________________________________________________________Yahoo! Music UnlimitedAccess over 1 million songs.http://music.yahoo.com/unlimited
Expecting? Get great news right away with email Auto-Check.Try the Yahoo! Mail Beta.
Thanks Sean, great pictures I think that I will
install the mast light were you have the antenna.
Your cap is is an idea I did not think of. I wonder
if its possible to shrink wrap a rubber cap?
regular drill bit.
the threads.
self-tapping.
roofers use.
in place.
antenae.
well.
penetrate.
Sean
do the same
Chrlie
Freedom,
soon to be
my
father and his
at the mast and now
in the mast to
elements
(snow/rain/bird
Also see: http://www.freedom21.info/images/bluemerle/BMTopOfMast.jpg The black is vinyl electrical tape around the original black plastic cap. I’ll search the forum for my previous posting(s) detailing all of the brackets on top. -John charles dzwonkowski <cskidwain@…> wrote: Thanks Sean, great pictures I think that I
willinstall the mast light were you have the antenna. Your cap is is an idea I did not think of. I wonderif its possible to shrink wrap a rubber cap?— Sean Mulligan <quadmulligan@yahoo.com> wrote:> Doug/Charie:> > Take a look at this photo:> >http://www.seanmulligan.com/Stories/Deliverance/target16.html> > I drilled new nole with a cordless drill and> regular drill bit.> I drilled a little smaller than the diameter of> the threads.> The stainless steel panhead screws are> self-tapping.> The open end is covered with rubber membrane> roofers use.> Our sail loft gave it to us. A band clamp holds it> in place.> I covered the bandclamp with black PVC tape.> I had to make sure
the wind indicator cleared the> antenae.> After PVC tape I applied liquid electrical tape as> well.> White silicone caulk fills hole where wires> penetrate.> > Let us know what you come up with.> > Sean> > charles dzwonkowski <cskidwain@yahoo.com> wrote:> Doug great question I myself am about to> do the same> exact work on my carbon fibor mast. I hope some one> has an answer for us.> Chrlie> — Doug Chace <ch47_av8r@yahoo.com> wrote:> > > I’ve spent the last few weekends getting my> Freedom,> > soon to be > > christended the Maccochaque II (pronounced> > Mack-A-Jack. Maccochaque is > > a Shawnee Indian word that means “place of> > refreshment.” It also > >
happens to be the name of the grade school where> my> > father and his > > siblings attended.) ready for paint. I was looking> > at the mast and now > > have the following questions:> > > > What experience have any of you had drilling holes> > in the mast to > > accommodate electrical wiring (mast light)?> > > > What do you use to cap the mast to keep the> elements> > (snow/rain/bird > > droppings/squirrel nests) from running down the> > inside of the hollow > > mast tube and accumulating in the cabin?> > > > Thanks,> > Doug> > > > > >__________________________________________________________> Yahoo! Music Unlimited> Access over 1 million songs.> http://music.yahoo.com/unlimited> > > > > > ---------------------------------> Expecting? Get great news right away with email> Auto-Check.> Try the Yahoo! Mail Beta.__________________________________________________________The fish are biting. Get more visitors on your site using Yahoo! Search Marketing.http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
-John
will
regular drill bit.
the threads.
self-tapping.
roofers use.
in place.
antenae.
well.
penetrate.
Sean
do the same
one
Chrlie
Freedom,
soon to be
my
father and his
looking
at the mast and now
holes
in the mast to
elements
(snow/rain/bird
-John
will
regular drill bit.
the threads.
self-tapping.
roofers use.
in place.
antenae.
well.
penetrate.
Sean
do the same
one
Chrlie
Freedom,
soon to be
my
father and his
looking
at the mast and now
holes
in the mast to
elements
(snow/rain/bird
