Re: AGM''s
Larry,
I just installed 4 AGM’s, and I read a lot about them: they can be
charged like wet lead/acid batteries. The manual of my Freedom/
Xantrex charger/inverter says so too, although there is a special
AGM setting on the charger/inverter.
Only Gell cells need different charging voltages.
This is what I picked up from all the docs.
— In FreedomOwnersGroup@yahoogroups.com, Larry Kraus
<kracherlandl@…> wrote:
Hi all,
The lead/acid batts on the F32 are in a small compartment below
steps. Tough to add water without disconnecting and removing each
batt.
Has anyone tried the Qwik-Fill system that allows remote filling
of
difficult to reach batts in sailboats and RVs. Any problems?
I’m looking into AGMs or Optimas, but have to replace the voltage
regulator and the battery charger. Not inexpensive. So may stick
with
the lead/acid for awhile longer.
Any thoughts…
Larry Kraus
Windsonnet F32
