Re: Digest Number 533
Posted by Robert Brown (bob.brown@…>)
Paul,
If you have an actual copy of the section in NFPA 58 that talks about
horizontal tanks I would appreciate a copy/scan of that so I can stick
it to my tank as the FAQ suggests is required.
Bob
Carina F32
Message: 2
Date: Thu, 21 Apr 2005 09:37:43 -0700 (PDT)
Subject: Re: F-32 Propane Question
Probably the easiest way is to go to
www.npga.org/files/public/consumers_questions.pdf Page 3 has the specific info
about the horizontal bottles. If you have a problem, I can scan my copy and send
it to you, or whoever…PWM
Bob,
I don’t have a copy of NFPA 58. They can be purchased for between $45.00 (amazon) and $119.95. I have never needed the handbook, the Q & A has worked every time, but I suppose there is a hardhead out there somewhere…
The Dangerfield note indicating that he had OPD’s installed on his F-32 bottles is the second time I’ve heard that. Tried to reply, and write direct back but got the good ol “Dameon failure” (sp) message back both times. Anyway I’m going to do some research and see what I come up with. I’ll post it on the board with the appropriate documentation either way.
PWMRobert Brown <bob.brown@…> wrote:
Paul,If you have an actual copy of the section in NFPA 58 that talks about horizontal tanks I would appreciate a copy/scan of that so I can stick it to my tank as the FAQ suggests is required.Thanks,BobCarina F32>Message: 2 > Date: Thu, 21 Apr 2005 09:37:43 -0700 (PDT)> From: Paul McFadden <pwhitmac@…>>Subject: Re: F-32 Propane Question>>Probably the easiest way is to go to www.npga.org/files/public/consumers_questions.pdf Page 3 has the specific info about the horizontal bottles. If you have a problem, I can scan my copy and send it to you, or whoever…PWM> >> >__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
