Gentelmen
Remember that when your cranking, the engine weter pump is pumping raw water into the exhaust systme thus filling the water-lift muffler and exhause hoses. If you crank too long, the muffler will fill and backflood into the engine.
I do not recommend shutting off the raw water inlet as a solution as the impeller may wipe the waterpump walls dry and then be dammaged.
Water lift mufflers have drains installed to allow draining for winterizing end preventing flodding the cylinder(s).
Brian
I replace my impeller every spring and
throw the old in the old but still good stuff box just in case. If you coat
the impeller with Vaseline, yeah I know only for dry lips, not condoms, and
other such items, it is absolutely new looking when I pull it out. So running
the engine with the raw intake off does not seem to hurt it at all. But
remember if its only < 50 rev without water its not going to hurt it much.Â
As for the water muffler I have never drained it just pump the antifreeze it
until it spits out the back of the boat…… no problem no shoe no worries…….
Bob
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Brian Guptil
Sent: Friday, November 21, 2008
3:03 PM
Extended cold weather cranking risks.
Â
Gentelmen
dammaged.
Brian
