Re: F21 GUNMOUNT
Posted by jborigin@… (jborigin@…)
any advice on putting a plastic sleeve on the gunmount mine is missing and I want to rig up the spinnaker.
thank you.
Pictures of your gummount lines and rigging would be wonderful.
Fee free to email direct if you like
Jborigin@…
J
84 F21
I’ll send you some pictures to your aol address. There’s a long piece on the gunmount which I’ll copy and send also.
Allen
Sent: Sunday, September 12, 2004 8:59 PM
Subject: Re: [freedomyachts2003] F21 GUNMOUNT
thank you.
Jborigin@…
J
84 F21
Measure the inside diameter of your stainless tube. Get a short
length of PVC pipe, 1/2 inch larger in diameter than the inside of
your stainless tube. Cut the length of the PVC so that it will be
slightly longer than the stainless tube. Lengthwise, cut a 1/2 inch
strip out of the PVC from one end to the other. Compress the PVC and
slide it into the stainless tube. The PVC will try to expand to its
original diameter, and this should give enough outward pressure to
retain it in the stainless tube. This is the quickest and easiest
way to make a liner for the gunmount tube. Charlie F 21 # 212
missing and I
thank you.
Jborigin@a…
J
84 F21
Posted by Bill Howze (howzeb@…>)
J - in lieu of the sleeves, I’ve used plastic strips with adhesive
on the back sold in office supply stores for furniture gliders.
They’re about an inch wide and 4 -6 inches long, and just thick
enough so that three of them can be installed inside the gun mount.
missing and I
thank you.
Jborigin@a…
J
84 F21
