Re: Freedom 25 Lifting Keel/ Liner for gunmount tube
Simon. Your stainless gunmount tube should have a plastic liner, to
allow the pole to slide easily. My replacement method is: 1. measure
the inside diameter of the stainless tube. 2. Get a piece of PVC
pipe, the length of the stainless tube, but one inch LARGER in
diameter. 3. Lengthwise, slice out a one inch section of the PVC. 4.
Squeeze the pvc tube together, and insert the pvc into the stainless
tube. Since the pvc was originally one inch larger than the stainless
tube, it will exert outward pressure on the inside of the steel tube,
keeping it in place. Good luck and happy sailing. Charlie on Mobile
Bay.
— In freedomyachts2003@yahoogroups.com, “Simon Dubberley”
<simon@s…> wrote:
What plastic sleeve? Please explain. Am I missing something vital
and is this the reason my gun mount system is so hard to use?
Back to the previous subject, my 25 is an American boat built by T
and P.
Simon
Sent: Thursday, November 03, 2005 1:36 PM
Subject: Re: [freedomyachts2003] Re: Freedom 25 Lifting Keel
Dave and Simon
I do not believe any lifting keel models were sold in US or
Canada.
Does any of you know where I could purchase a plastic sleeve for
my F25 Gun Mount.
Andre " Scaramanga "
Simon Dubberley <simon@s…> wrote:
Dave,
Correct. Freedom 25 with a hydraulic vertical lifting keel. My
hull number/sail number is 129. I think mine is the only example in
the U.K.
Simon
  Sent: Thursday, November 03, 2005 4:03 AM
  Subject: [freedomyachts2003] Re: Freedom 25 Lifting Keel
  I never knew Freedom made a lifting keel version of the F-25.
Dammit
  I want one! We're talking about the 25 right? Not the 24
which was
  only made in small numbers. Were there any lifting keel
models with
  rotating masts?
  --- In <freedomyachts2003@yahoogroups.com>, "simon_dubberley"
  <simon@s...> wrote:
  > Has anyone altered the method of securing the lifting keel
when in
  > lowered position? Last weekend in bad weather the stainless
plates
  > parted company with the keel casing letting the keel move
rather
  > excessively! Alarming to say the least. Has anyone thru
bolted the
  > lowered keel?
  > Simon
  Checked by AVG Free Edition.
  Version: 7.1.362 / Virus Database: 267.12.7/155 - Release
Date: 01/11/2005
SPONSORED LINKS Sailing schools Sailing instruction Sailing
lesson
Sailing course Sailing adventure Sailing
YAHOO! GROUPS LINKS
a..  Visit your group "freedomyachts2003" on the web.
b..  To unsubscribe from this group, send an email to:
c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date:
01/11/2005
Posted by Simon Dubberley (simon@…>)
Charlie,
Many thanks for the info I nearly gave-up on the bloody thing. I’ll go down to the boat yard tomorrow and measure!
Simon “Toad” Anglesey North Wales.
Sent: Friday, November 04, 2005 8:55 PM
Subject: [freedomyachts2003] Re: Freedom 25 Lifting Keel/ Liner for gunmount tube
Simon. Your stainless gunmount tube should have a plastic liner, to allow the pole to slide easily. My replacement method is: 1. measure the inside diameter of the stainless tube. 2. Get a piece of PVC pipe, the length of the stainless tube, but one inch LARGER in diameter. 3. Lengthwise, slice out a one inch section of the PVC. 4. Squeeze the pvc tube together, and insert the pvc into the stainless tube. Since the pvc was originally one inch larger than the stainless tube, it will exert outward pressure on the inside of the steel tube, keeping it in place. Good luck and happy sailing. Charlie on Mobile Bay. — In freedomyachts2003@yahoogroups.com, “Simon Dubberley” <simon@s…> wrote:>> What plastic sleeve? Please explain. Am I missing something vital and is this the reason my gun mount system is so hard to use? > > Back to the previous subject, my 25 is an American boat built by T and P.> > Simon > ----- Original Message ----- > From: andre laviolette > To: freedomyachts2003@yahoogroups.com > Sent: Thursday, November 03, 2005 1:36 PM> Subject: Re: [freedomyachts2003] Re: Freedom 25 Lifting Keel> > > > Dave and Simon> > I do not believe any lifting keel models were sold in US or Canada.> > Does any of you know where I could purchase a plastic sleeve for my F25 Gun Mount.> > Andre " Scaramanga "> Simon Dubberley <simon@s…> wrote:> Dave,> > Correct. Freedom 25 with a hydraulic vertical lifting keel. My hull number/sail number is 129. I think mine is the only example in the U.K.> > Simon> ----- Original Message ----- > From: Dave_Benjamin > To: freedomyachts2003@yahoogroups.com > Sent: Thursday, November 03, 2005 4:03 AM> Subject: [freedomyachts2003] Re: Freedom 25 Lifting Keel> > > I never knew Freedom made a lifting keel version of the F-25. Dammit > I want one! We’re talking about the 25 right? Not the 24 which was > only made in small numbers. Were there any lifting keel models with > rotating masts?> > > > — In freedomyachts2003@yahoogroups.com, “simon_dubberley” > <simon@s…> wrote:> >> > Has anyone altered the method of securing the lifting keel when in > the > > lowered position? Last weekend in bad weather the stainless plates > > parted company with the keel casing letting the keel move rather > > excessively! Alarming to say the least. Has anyone thru bolted the > > lowered keel?> > > > Simon> >> > > > > > > > --------------------------------------------------------------------------> > > No virus found in this incoming message.> Checked by AVG Free Edition.> Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 01/11/2005> > > > ------------------------------------------------------------------------------> Find your next car at Yahoo! Canada Autos > > SPONSORED LINKS Sailing schools Sailing instruction Sailing lesson > Sailing course Sailing adventure Sailing > > > ------------------------------------------------------------------------------> YAHOO! GROUPS LINKS > > a… Visit your group “freedomyachts2003” on the web.> > b… To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------> > > > > ------------------------------------------------------------------------------> > > No virus found in this incoming message.> Checked by AVG Free Edition.> Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 01/11/2005>
No virus found in this incoming message.Checked by AVG Free Edition.Version: 7.1.362 / Virus Database: 267.12.8/161 - Release Date: 03/11/2005
Dave and Simon
Canada.
Dave,
keel. My
in
the U.K.
I’m not surprised. I’m not an expert on Freedoms but I was pretty
sure there were no 25’s made in North America with a lifting keel.
The 24’s are cool boats but they are not very common and tend to be
expensive. I’ve noticed the ones that go on the market tend to take
quite a while to sell.
