RE: [freedomyachts2003] RE- Propane Cylinders
I’m not sure this went so will send again.Sward <swardfullsail@…> wrote: If anyone is interested I have a great way to install a 20lb tank: I bought a horizontal 20 lb tank that has the bracket for installation on it. I made a piece of starboard to fit the back rail-8" X 24" that is U-bolted onto the stern railings. The tank is then bolted onto that on the outside of the rail. It gets the tank off the deck-out of the way of the cockpit, but within reach of the propane fill area-an extension hose was attached and a hole drilled in the stern to the other propane locker. It works great. Hope this is helpful to anyone fredmolden <fredmolden@…> wrote: When the tank is horizontal the overfill device is activated and shuts offthe flow of gas. This is also true of “plumber” propane tanks which areoften laid on their side while the plumber heats a joint. A plumber tank isalso exempt. Bear in mind that a propane tank is filled with liquid propaneand only the gas is used. When on its side the liquid is in the valve.-----Original Message-----From: freedomyachts2003@yahoogroups.com[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Larry KrausSent: Wednesday, January 09, 2008 9:35 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] RE- Propane CylindersHi Al,I’ve never actually seen the over fill device, but my guess is that they use some type of float that relies on vertical travel in order to work. There’s not much vertical travel in a horizontal tank. That’s all I can figure. But I’ll ask next time I have mine filled.LKAl Lorman wrote:> I’ve never known why, but horizontal tanks are exempt.>> Law Office of> Alvin J. Lorman> 1629 K Street, NW, Suite 300> Washington, DC 20006> Tel/Fax:
202.263.1100> Cell: 202.236.2359>> Sent from my BlackBerry Wireless >> -----Original Message-----> From: Larry and Linda Kraus <kracherlandl@bitstream.net>>> Date: Tue, 08 Jan 2008 22:55:53 > To:freedomyachts2003@yahoogroups.com> Subject: Re: [freedomyachts2003] RE- Propane Cylinders>>> Sorry but I disagree. The horizontal tanks cannot be fitted with the new > overfill device that is now common on the tanks for the everyday grill. > They are somehow exempt from the overfill device regulation. At least > that’s what my local gas company tells me when they fill them.> > LK> > dfcreedon@comcast. mailto:dfcreedon%40comcast.net net wrote:> >> > 7 lbs and you cannot get
them refilled due to the connector> >> > -------------- Original message ----------------------> > From: “Michael Gillin” <michael_w_gillin@mailto:michael_w_gillin%40snet.net snet.net > > mailto:michael_w_gillin%40snet.net>> > > Hi Folks ; Can anyone assist in telling me how I should go about> > > recertifying the original propane cylinders that are located in the> > > port & stbd cockpit lockers.> > >> > > Has anyone gone through the process and had them filled again.> > > Or has anyone abandoned them and gone to a different propane tank.> > >> > > I would like to get these refilled but I am at a loss determining the> > > lbs and what to ask for.> > >> > >> > > Thanks> > >> > > Captain
Michael> > >> > >> > >> > >> >> > > > ----------------------------------------------------------> >> > Subject:> > [freedomyachts2003] RE- Propane Cylinders> > From:> > “Michael Gillin” <michael_w_gillin@mailto:michael_w_gillin%40snet.net snet.net>> > Date:> > Tue, 8 Jan 2008 23:26:50 +0000> > To:> > freedomyachts2003@ mailto:freedomyachts2003%40yahoogroups.comyahoogroups.com> >> > To:> > freedomyachts2003@ mailto:freedomyachts2003%40yahoogroups.comyahoogroups.com> >> >> > Hi Folks ; Can anyone assist in telling me how I should go about> > recertifying the original propane cylinders that are located in the> > port
& stbd cockpit lockers.> >> > Has anyone gone through the process and had them filled again.> > Or has anyone abandoned them and gone to a different propane tank.> >> > I would like to get these refilled but I am at a loss determining the> > lbs and what to ask for.> >> > Thanks> >> > Captain Michael> >> > >> > Yahoo! Groups Links>>>>>> Yahoo! Groups Links “Life is a Reach, then you Jibe” SWARD"Life is a Reach, then you Jibe" SWARD
Posted by Capt. Herman (sailtampa@…>)
Greetings…
I took both of my custom aluminum tanks to suburban propane…they directed me to a propane equipment dealer for the correct overflow protection valves…I purchased 2 …and Suburban installed them , certified the tanks, and filled them…
very helpful yardman at Suburban…you might call a local propane company, and they might be able to assist you if you need new valves and certification…
I am in Tampa…
Capt.Herman "Whitewing’
Sent: Wednesday, January 09, 2008 12:28 PM
Subject: [FreedomOwnersGroup] RE: [freedomyachts2003] RE- Propane Cylinders
I’m not sure this went so will send again.Sward <swardfullsail@yahoo.com> wrote:
fredmolden <fredmolden@comcast.net> wrote:
When the tank is horizontal the overfill device is activated and shuts offthe flow of gas. This is also true of “plumber” propane tanks which areoften laid on their side while the plumber heats a joint. A plumber tank isalso exempt. Bear in mind that a propane tank is filled with liquid propaneand only the gas is used. When on its side the liquid is in the valve.-----Original Message-----From: freedomyachts2003@yahoogroups.com[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Larry KrausSent: Wednesday, January 09, 2008 9:35 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] RE- Propane CylindersHi Al,I’ve never actually seen the over fill device, but my guess is that they use some type of float that relies on vertical travel in order to work. There’s not much vertical travel in a horizontal tank. That’s all I can figure. But I’ll ask next time I have mine filled.LKAl Lorman wrote:> I’ve never known why, but horizontal tanks are exempt.>> Law Office of> Alvin J. Lorman> 1629 K Street, NW, Suite 300> Washington, DC 20006> Tel/Fax: 202.263.1100> Cell: 202.236.2359>> Sent from my BlackBerry Wireless >> -----Original Message-----> From: Larry and Linda Kraus <kracherlandl@bitstream.net>>> Date: Tue, 08 Jan 2008 22:55:53 > To:freedomyachts2003@yahoogroups.com> Subject: Re: [freedomyachts2003] RE- Propane Cylinders>>> Sorry but I disagree. The horizontal tanks cannot be fitted with the new > overfill device that is now common on the tanks for the everyday grill. > They are somehow exempt from the overfill device regulation. At least > that’s what my local gas company tells me when they fill them.> > LK> > dfcreedon@comcast. mailto:dfcreedon%40comcast.net net wrote:> >> > 7 lbs and you cannot get them refilled due to the connector> >> > -------------- Original message ----------------------> > From: “Michael Gillin” <michael_w_gillin@mailto:michael_w_gillin%40snet.net snet.net > > mailto:michael_w_gillin%40snet.net>> > > Hi Folks ; Can anyone assist in telling me how I should go about> > > recertifying the original propane cylinders that are located in the> > > port & stbd cockpit lockers.> > >> > > Has anyone gone through the process and had them filled again.> > > Or has anyone abandoned them and gone to a different propane tank.> > >> > > I would like to get these refilled but I am at a loss determining the> > > lbs and what to ask for.> > >> > >> > > Thanks> > >> > > Captain Michael> > >> > >> > >> > >> >> > > > ----------------------------------------------------------> >> > Subject:> > [freedomyachts2003] RE- Propane Cylinders> > From:> > “Michael Gillin” <michael_w_gillin@mailto:michael_w_gillin%40snet.net snet.net>> > Date:> > Tue, 8 Jan 2008 23:26:50 +0000> > To:> > freedomyachts2003@ mailto:freedomyachts2003%40yahoogroups.comyahoogroups.com> >> > To:> > freedomyachts2003@ mailto:freedomyachts2003%40yahoogroups.comyahoogroups.com> >> >> > Hi Folks ; Can anyone assist in telling me how I should go about> > recertifying the original propane cylinders that are located in the> > port & stbd cockpit lockers.> >> > Has anyone gone through the process and had them filled again.> > Or has anyone abandoned them and gone to a different propane tank.> >> > I would like to get these refilled but I am at a loss determining the> > lbs and what to ask for.> >> > Thanks> >> > Captain Michael> >> > >> > Yahoo! Groups Links>>>>>> Yahoo! Groups Links
SWARD
SWARD
