Posted by j32080 (j32080@…>)
http://www.freedom21.info/gunmountingsleeve.htm
-JohnFormer owner Blue Merle (#259)
— In freedom21@yahoogroups.com, “Charlie L.” <clivaday@…> wrote:>> The best and easiest way to make a gunmount sleeve lining is: get a > piece of pvc pipe-1/2 inch larger in diameter than the inside of the > gunmount tube–and the same length as the gunmount tube. Lengthwise, > cut out a section of the pvc-1/2 inch wide, for the length of the > pvc. Squeeze the pvc and insert in to the tube. The pvc will want to > expand to its original diameter, thereby placing outward pressure > onto the inside of the tube-keeping the pvc in place. Charlie > >
