…would be nice controversial subject to carry on with…
To start the subject:
I have a standard alarm flare gun on board, with license. Plus one
meter of PVC drain pipe that fits snugly over the barrel of the flare
gun…
Some old salt told me that with a large cartridge I can torch a pirate
vessel at 100 meters.
— In FreedomOwnersGroup@yahoogroups.com, george huffman
<thatboatguy2@…> wrote:
Oh its on now Macks!� heh heh�
But on the serious side let it be known that the following is meant
in the spirit of information and oppinion sharing; is in no way
personal, and is not intended to inflame.�Actually 5200 is both adhesive and sealant.� If I want to remove
that through hull (even after the 52 day nominal cure time) I can do
it quite easily because I know how.� :)� I would not dream of
attaching or installing anything near or below the waterline with
anything but 5200.� I realize this is opinion but it is a professional
opinion that is widely shared.� As for a bigger hammer… well…
whenever I’m criticized for overkill where crew safety is involved I
just smile and carry on.� :)� Incidently, some teak cleaners will
soften 5200 over time.� Just an FYI for anyone with a teak rubrail or
trim near a hull/deck joint that has been assembled with 5200.But thanks for watching my 6 on that silicone issue.� :)�
Next I think we should maybe discuss the merits of guns onboard or
maybe best anchor… ;)�George
— On Thu, 11/20/08, macks011 <macks02@…> wrote:
Subject: [FreedomOwnersGroup] Re: Hull thickness
Date: Thursday, November 20, 2008, 8:13 AMPlease, I don't want to start a flame war, but: 5200 or
any variant
is a polyurethane. Polyurethane is an ADEHESIVE and as such should
never be used for anything you might have to remove. Some of the few
marine uses are hull/deck joints, hull/keel joints and mast step
beddings.
Below and above waterline hardwere should be bedded with a
Polysulfide. Polysulfide is a CAULK and/or Bedding Compound and is
the best all around material for these jobs.
Last but not least is Silicone. Silicone has high flex propertiesand its primary purpose is in bedding portlights.
We all hve a tendency to use a bigger hammer, more is better andall that. 5200 will not prevent a leak, it will only make it a bitch
to fix one.
— In FreedomOwnersGroup@ yahoogroups. com, “George Huffman”
<thatboatguy2@ …> wrote:
It never ceases to amaze me how thick our hull is. Two inches thick
including an inch of balsa. I just made a hole for an a/c thru hull
(exit) and installed a bronze through hull (don’t cringe Skip I used
5200!
). I was also proud and happy to see how dry that core
was.
Freedom 40 CK CC Hull number 7
