Re: New anchor recommendation
Posted by Peter Schäfer (petersch@…>)
There is a new anchor from New Zealand called the Rocna anchor. It seems to
be a combination of the Delta (shank), the Spade (fluke) and the German
Buegel anchor. The tests are quite promising. Have a look at it under
http://www.rocna.com
Greetings,
Peter
Peter,
I’ve had a look, and it looks like the best anchor one could have,
because indeed it is a crossover of Bügel, Spade and Delta. A problem
however seems to be the roll bar/bügel. On most standard Freedom
anchor catheads, the roll bar interferes with the closed front of the
cathead. I’ll have to see if my supplier is willing to order one in
the right size with the right of return, so I can ‘try it on’.
— In freedomyachts2003@yahoogroups.com, Peter Schäfer <petersch@…>
seems to
German
Greetings,
Peter
I first heard of this anchor when
following Steve Dashew’s postings on setsail.com. He switched to a ROCNA
after many years of very heavy Bruce anchors. I’d guess he was very
careful before doing so.
But I assumed the roll bar would be a problem
as you say. If you get one let me know how it fits.
I currently have a 44lb delta on my F-33. Much
happier then with the CQRs I used for many years on a previous boat and initially
on the F-33. Was thinking of an aluminum spade but just wasn’t completely
convinced of the aluminum construction.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel
Sent: Wednesday, July 26, 2006
5:14 PM
Peter,
seems to
German
Greetings,
Peter
Steve Dashew is a hard act to follow…but let me throw in my two cents. We have been at anchor for most of the last 8 months our our travels from Connecticut to southern Florida and back in our Freedom 30. Conditions have varied from crystal clear stillness to gale conditions…with many squalls in the forty knot + range (recorded on our B&G masthead unit). Our primary anchor is a Bulwagga 17 pound anchor…which I purchased on the basis of a Practical Sailor review. While it is a rather ugly piece of steel craft…it is a fantastic anchor. It sets quickly and holds tenaciously. Anchors have lots of fans and fanatics…and many have reached the status of acceptance…inspite of inconsistant and even dangerous performance. The Bulwagga has earned its place on our boat by real performance…when all hell was breaking loose just the other side our our little eggshell. Give it look. FargoF30#12
NARISAAlan Kusinitz <akusinitz@…> wrote: I first heard of this anchor when following Steve Dashew’s postings on setsail.com. He switched to a ROCNA after many years of very heavy Bruce anchors. I’d guess he was very careful before doing so. But I assumed the roll bar would be a problem as you say. If you get one let me know how it fits. I currently have a 44lb delta on my F-33. Much happier then with the CQRs I used for many years on a previous boat and initially on the F-33. Was thinking of an aluminum spade but just wasn’t completely convinced of the aluminum construction. Alan ********************************************************************** The information contained in this e-mail and any attachments is intended only for the personal and confidential use of the recipient(s) named above and may be subject to attorney client privilege if so marked. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail, and delete the original message. ********************************************************************** From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel Sent: Wednesday, July 26, 2006 5:14 PM To: freedomyachts2003@yahoogroups.com Subject: [freedomyachts2003] Re: New anchor recommendation Peter, I’ve had a look, and it looks like the best anchor one could have, because indeed it is a crossover of Bügel, Spade and Delta. A problem however seems to be the roll bar/bügel. On most standard Freedom anchor catheads, the roll bar interferes with the closed front of the cathead. I’ll have to see if my supplier is willing to order one in the right size with the
right of return, so I can ‘try it on’. Michel — In freedomyachts2003@yahoogroups.com, Peter Schäfer <petersch@…> wrote: > > There is a new anchor from New Zealand called the Rocna anchor. It seems to > be a combination of the Delta (shank), the Spade (fluke) and the German > Buegel anchor. The tests are quite promising. Have a look at it under > > http://www.rocna.com > > Greetings, > Peter >
I’ve been very interested in the
Bulwagga especially due its potential performance in weed/grass. But its shape
presents challenges. How did you mount it?
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Fargo Rousseau
10:20 PM
Subject: RE: [freedomyachts2003]
Steve
Fargo
F30#12 NARISA
Alan Kusinitz
before doing so.
Alan
5:14 PM
Peter,
Rocna anchor. It
seems to
German
Greetings,
Peter
Rocna has drawings with all sizes of their anchors; very convenient.
I’ll size things up and see if one fits, preferably the 25 kgs one.
If you have a 44 lbs Delta, I would stick to that; fine and good
sized anchor for an F33, I would think. I must say I never had
problems with my 35 lbs CQR on my F33/35 ck, but I never anchored in
extreme weather.
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
on
Bruce
get one let
the CQRs I
Was
of the
Alan
intended
named above
the reader
responsible for
that you
dissemination,
you have
by
Peter,
problem
— In freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
yahoogroups.com, Peter Schäfer <petersch@>
It
seems to
German
under
http://www.rocna. http://www.rocna.com com
Greetings,
Peter
Mounting on an F30 is easy. The main shaft of the Bulwagga lays down in the standard bow fitting and the flukes clear the hull. A serious advantage to this anchor is weight. It is the best holding and best setting anchor under 20 lbs for this boat. We don’t have an anchor windless so weight is an issue (although a good night sleep in squally weather is much more important). FargoAlan Kusinitz <akusinitz@…> wrote: I’ve been very interested in the Bulwagga especially due its potential performance in weed/grass. But its shape presents challenges. How did you mount it? Alan ********************************************************************** The information contained in this e-mail and any attachments is intended only for the personal and confidential use of the recipient(s) named above and may be subject to attorney
client privilege if so marked. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail, and delete the original message. ********************************************************************** From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Fargo Rousseau Sent: Wednesday, July 26, 2006 10:20 PM To: freedomyachts2003@yahoogroups.com Subject: RE: [freedomyachts2003] Re: New anchor recommendation Steve Dashew is a hard act to follow…but let me throw in my two cents. We have been at anchor for most of the last 8 months our our travels from Connecticut to southern Florida and back in our Freedom 30. Conditions have varied from crystal clear stillness to gale conditions…with many squalls in the forty knot + range (recorded on our B&G masthead unit). Our primary anchor is a Bulwagga 17 pound anchor…which I purchased on the basis of a Practical Sailor review. While it is a rather ugly piece of steel craft…it is a fantastic anchor. It sets quickly and holds tenaciously. Anchors have lots of fans and fanatics…and many have reached the status of acceptance…inspite of inconsistant and even dangerous performance. The Bulwagga
has earned its place on our boat by real performance…when all hell was breaking loose just the other side our our little eggshell. Give it look. Fargo F30#12 NARISA Alan Kusinitz <akusinitz@yahoo.com> wrote: I first heard of this anchor when following Steve Dashew’s postings on setsail.com. He switched to a ROCNA after many years of very heavy Bruce anchors. I’d guess he was very careful before doing so. But I assumed the roll bar would be a problem as you say. If you get one let me know how it fits. I currently have a 44lb delta on my F-33. Much happier then with the CQRs I used for many years on a previous boat and initially on the F-33. Was thinking of an aluminum spade but just wasn’t completely convinced of the aluminum construction. Alan ********************************************************************** The information contained in this e-mail and any attachments is intended only for the personal and confidential use of the recipient(s) named above and may be subject to attorney client privilege if so marked. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel Sent: Wednesday, July 26, 2006 5:14 PM To: freedomyachts2003@yahoogroups.com Subject: [freedomyachts2003] Re: New anchor recommendation Peter, I’ve had a look, and it looks like the best anchor one could have, because indeed it is a crossover of B�gel, Spade and Delta. A
problem however seems to be the roll bar/b�gel. On most standard Freedom anchor catheads, the roll bar interferes with the closed front of the cathead. I’ll have to see if my supplier is willing to order one in the right size with the right of return, so I can ‘try it on’. Michel — In freedomyachts2003@yahoogroups.com, Peter Sch�fer <petersch@…> wrote: > > There is a new anchor from New Zealand called the Rocna anchor. It seems to > be a combination of the Delta (shank), the Spade (fluke) and the German > Buegel anchor. The tests are quite promising. Have a look at it under > > http://www.rocna.com > > Greetings, > Peter >
