Jay,
Thanks a lot for your good advice!
Do you know how to get the ends off the heat exchanger? The bolts
are coming out quite easily, but I don’t see a way to get these lids
off. I’m hesitant to put a large wrench on the end and just start
turning the lid off.
Are these two hose clamps around the heat exchanger the only
fasteners? It looks like there is also a platform that is attached
to the engine back. Or is this just where the hoseclamps sit around?
Thanks!
— In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:
When changing your thermostat on the 4-108, it is alot easier if
you
remove both bolts on top of the header tank. One is a bolt that
comes out
quite easily, the other is a long stud and is more difficult to
remove.
Be careful not to shear it off, if you do you will have to extract
broken stud fromthe head. If you do not remove these two bolts it
is
almost impossible to remove the header tank due to the hose
connecting
the tank to the exhaust manifold, and the rigid copper tubing
(return
line) from the exhaust manifold to the header tank. I just did mine
today. When reassembling, be careful not to disturb the new gasket
or
damage the top of the new thermostat when placing the tank back
into
position. Also, concerning the heat exchanger (mine is also at the
rear
of the engine under the oil filter), always use two wrenches when
removing the zinc. One on the zinc plug and the other on the
fitting on
the tank. These copper tanks are very soft and it is easy to tear
fitting right out of the tank if the plug is very tinght. Also,
make sure
you place rubber protectors under the hose clamps used to secure
the tank
in place. Otherwise, the clamps will severely dent the tank, which
usually results in no warranty when a shop boils and services the
exchanger. Good luck!
Jay Glen
S/V Fantasy F-40 San Francisco Bay
Subject: [freedomyachts2003] Re: Perkins 4107/4108 thermostat
location?
Date: Wed, 12 Apr 2006 23:54:15 -0000
I’d bet on the heat exchanger. Mine was pretty disgusting before
I
had it boiled - I don’t think the zinc had been changed in the
previous two seasons. When I pulled the zinc plug, the zinc was
firmly jammed into the heat exchanger. I’ve written about this
before, but if you decide to remove the heat exchanger, do
yourself
a favor and drain the oil and remove the filter. then getting the
exchanger off is a piece of cake.
<michel.capel@> wrote:
Jerome,
Thanks for the tip. I think my raw water inlet is okay because
water is always spurting out of the exhaust in the transom.
However,
the raw water goes out as cold as it comes in, so I suspect I
have
a
problem in the fresh water side of the cooling system. A
blockage,
hopefully in the thermostat or the heat exchanger is what I’m
thinking of first.
— In freedomyachts2003@yahoogroups.com, Jerome Weinraub
<zayde@> wrote:
Before you go into the engine,check the saltwater inlet
hose.Old
ones can
collapse under vacuum. As to Westerbeke,email them-I hear
they
are
helpful.
Sent: Tuesday, April 11, 2006 5:01 PM
Subject: [freedomyachts2003] Perkins 4107/4108 thermostat
location?
Hi All,
Alabama Queen survived the trip from Mobile to Flushing,
Netherlands. However, she’s a bit of a Southern hothead
girl,
and her
engine is overheating. In the course of solving this, I
want to
replace the thermostat. But where is it?? I almost long
back
to
days of my Volvo Penta 2003 in the F33… Does anybody
know
where the
thermostat is located on a lowline 1980 early 4.108
Perkins?
Besides: this engine is really a hybride
Perkins/Westerbeke;
block
is Perkins, but the exhaust elbow and the heat exchanger
are
Westerbeke parts; who knows which parts also; is this
common??
cheers, and thanks for every tip,
Yahoo! Groups Links
SPONSORED LINKS
Sailing schools Sailing instruction Sailing lesson
Sailing course Sailing adventure Sailing
YAHOO! GROUPS LINKS
* Visit your group "freedomyachts2003" on the web.
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Michel,
the heat exchanger is held on by the hoses and the two bands. the
platform is attached to the back of the engine and the bands should go
around it and the exchanger. the lower hose on the port side is a PITA
to get on and off.
Also, when you refill the coolant, don’t forget that it’ll ‘burp’ and
you will have to add more.
Lance
<michel.capel@…> wrote:
Jay,
Thanks!
Posted by svfantasy@… (svfantasy@…)
If you have the same heat exchanger only the port side comes off by removing the single bolt. The other end is soldered on, so I recommend you have a pro do the work. You are correct, the exchanger sets into a cradle the the hose clamps secure it to. I understand Perkins also used a different exchanger on which both ends are removeable. Maybe you have this one. Good luck with your project.
Jay
----- Original Message -----From: “michel.capel” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Perkins 4107/4108 heat exchangerDate: Thu, 13 Apr 2006 09:36:38 -0000Jay,Thanks a lot for your good advice! Do you know how to get the ends off the heat exchanger? The bolts are coming out quite easily, but I don’t see a way to get these lids off. I’m hesitant to put a large wrench on the end and just start turning the lid off. Are these two hose clamps around the heat exchanger the only fasteners? It looks like there is also a platform that is attached to the engine back. Or is this just where the hoseclamps sit around?Thanks!Michel — In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:>> When changing your thermostat on the 4-108, it is alot easier if you> remove both bolts on top of the header tank. One is a bolt that comes out> quite easily, the other is a long stud and is more difficult to remove.> Be careful not to shear it off, if you do you will have to extract the> broken stud fromthe head. If you do not remove these two bolts it is> almost impossible to remove the header tank due to the hose connecting> the tank to the exhaust manifold, and the rigid copper tubing (return> line) from the exhaust manifold to the header tank. I just did mine> today. When reassembling, be careful not to disturb the new gasket or> damage the top of the new thermostat when placing the tank back into> position. Also, concerning the heat exchanger (mine is also at the rear> of the engine under the oil filter), always use two wrenches when> removing the zinc. One on the zinc plug and the other on the fitting on> the tank. These copper tanks are very soft and it is easy to tear the> fitting right out of the tank if the plug is very tinght. Also, make sure> you place rubber protectors under the hose clamps used to secure the tank> in place. Otherwise, the clamps will severely dent the tank, which> usually results in no warranty when a shop boils and services the> exchanger. Good luck!> > Jay Glen> > S/V Fantasy F-40 San Francisco Bay> > ----- Original Message -----> From: lance_ryley> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Re: Perkins 4107/4108 thermostat> location?> Date: Wed, 12 Apr 2006 23:54:15 -0000> > I’d bet on the heat exchanger. Mine was pretty disgusting before I> had it boiled - I don’t think the zinc had been changed in the> previous two seasons. When I pulled the zinc plug, the zinc was> firmly jammed into the heat exchanger. I’ve written about this> before, but if you decide to remove the heat exchanger, do yourself> a favor and drain the oil and remove the filter. then getting the> exchanger off is a piece of cake.> > — In freedomyachts2003@yahoogroups.com, “michel.capel”> <michel.capel@> wrote:> >> > Jerome,> > Thanks for the tip. I think my raw water inlet is okay because the> > water is always spurting out of the exhaust in the transom.> However,> > the raw water goes out as cold as it comes in, so I suspect I have> a> > problem in the fresh water side of the cooling system. A blockage,> > hopefully in the thermostat or the heat exchanger is what I’m> > thinking of first.> >> > Michel> >> >> > — In freedomyachts2003@yahoogroups.com, Jerome Weinraub> > <zayde@> wrote:> > >> > > Before you go into the engine,check the saltwater inlet hose.Old> > ones can> > > collapse under vacuum. As to Westerbeke,email them-I hear they> are> > helpful.> > > ----- Original Message -----> > > From: “michel.capel” <michel.capel@>> > > To: <freedomyachts2003@yahoogroups.com>> > > Sent: Tuesday, April 11, 2006 5:01 PM> > > Subject: [freedomyachts2003] Perkins 4107/4108 thermostat> location?> > >> > >> > > > Hi All,> > > >> > > > Alabama Queen survived the trip from Mobile to Flushing, the> > > > Netherlands. However, she’s a bit of a Southern hothead girl,> > and her> > > > engine is overheating. In the course of solving this, I want to> > > > replace the thermostat. But where is it?? I almost long back> to> > the> > > > days of my Volvo Penta 2003 in the F33… Does anybody know> > where the> > > > thermostat is located on a lowline 1980 early 4.108 Perkins?> > > >> > > > Besides: this engine is really a hybride Perkins/Westerbeke;> the> > block> > > > is Perkins, but the exhaust elbow and the heat exchanger are> > > > Westerbeke parts; who knows which parts also; is this common??> > > >> > > > cheers, and thanks for every tip,> > > > Michel> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > > Yahoo! Groups Links> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > >> >> > > > > > > SPONSORED LINKS> Sailing schools Sailing instruction Sailing lesson> Sailing course Sailing adventure Sailing> > --------------------------------------------------------------------> > YAHOO! GROUPS LINKS> > * Visit your group “freedomyachts2003” on the web.> > * To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> Service.> > > -------------------------------------------------------------------->
