Posted by j32080@…> (j32080@…>)
Max, Common problem. I used an electrical “snake” on mine. The thin plastic inside lining (from when the mast mas formed) came loose on mine. Try a shop vac with a couple of 10’ lengths of 1 1/2" PCV pipe and duct tape as a big “extension”. Should be cheap enough. You can get the mast clean as a whistle - I did. -John Max Lent <maxlent@…> wrote: Thanks for the encouragement. I wish it were so simple. After taking the cap off the mast and cleaning out the wasp nests, I discovered that I couldn’t see from one end of the mast to the other. Using a boat hook, I removed a birds nest from the bottom of the mast and there is still junk inside the mast that I haven’t been able to clear out. Somewhere in that black cavern is the end of an antenna cable that I have bring to the base of the mast so that I can replace the cable. I will also want to string a cable for the mast lights. Although your enthusiasm is appreciated, most of this work, seems to me, is best done before I step the mast and just go sailing. Since I will be living aboard the boat for days at a time while tied to a bouy, having a mast light seems like a good idea. If I have a working radio antenna, who knows, I may pick up your distress call. :-)This summer, I
have spent three days and nights aboard Top Cat sailing on the Erie canal. Based on how few sailboats I actually see leave thier slips in the marinas, that’s more time than most sailboat owners spend on their boats in a season. So, I’m doing pretty well all things considered.Anybody have any ideas on how to clean out a mast. I’m considering a chimney sweep.Max Lenthttp://www.maxlent.com
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
