Re: Re: Jib
Posted by j32080@…> (j32080@…>)
Allen,
A jib (staysail) is available for the Freedom 21. Actually two. A
“blade” and the “class”. See http://www.freedom21.info/f21sails.pdf
I bought the “class” staysail for my 21 (“Blue Merle”) directly from
Haarstick for about $500 (circa ~1996). See picture:
http://www.freedom21.info/images/bluemerle/BMMainJib.jpg
It is great in light air and for pointing. However, it needs to come
down above 10 knots of wind as the boat will be overpowered.
A worthwile investment. However, it does change your rating a bit.
You are no longer a “cat” rig, but a “sloop”. See the example ratings
from the PHRF NE site:
FREEDOM 21 CAT 255
FREEDOM 21 SLOOP 243
FREEDOM 21 SLOOP SD 252
Regards,
-John
Former “Blue Merle” owner (#259)
— Allen McClung <amcclung@…> wrote:
— Thanks, Sean. I looked through your pix yesterday and saw the one
you attached. I’ll give it a try. BTW, do you know where you can buy
slugs for the mainsail? I have one missing from the top and nobody in
docks has one like it.
From your other photos, it looks like you have a jib. I have a self-
tacking staysail but it doesn’t seem to help much. Most of the other
boats in my area are J-24s and they take delight in beating me in
races every week. I can pass them when running with the wind, but
they sail so much higher than I can on reaches.
n freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…> wrote:
MessageAllen - Spartite sells the kit for a bit over $100. You
follow directions, mix the 2 parts and pour into the gap (after
making a dam at the bottom between the mast and partners). The cured
Spartite is both structural and (mostly) water sealant. You don’t
need anything else and you can reuse it over and over (if you are
careful - as we were - see
http://www.seanmulligan.com/Stories/Emmylou307/target36.html).
Sean - Emmylou #307
-----Original Message-----
Thank you “emmylou’s” owner. Look at my boat on “Allen’s 21.” They
are even painted the same color. I’ll check out www.spartite.com.
Do
you put the collar on and then use the spartite or does the
Spartite
stuff take the place of the collar?
Allen
Yahoo! Mail goes everywhere you do. Get it on your phone.
Do You Yahoo!?
http://mail.yahoo.com
Thank you, John. I’ll go to Haarstick and price the class staysail.
— In freedom21@yahoogroups.com, <j32080@…> wrote:
Allen,
from
come
bit.
ratings
FREEDOM 21 CAT 255
Regards,
-John
the one
buy
nobody in
self-
other
in
but
cured
don’t
are
Sean - Emmylou #307
They
www.spartite.com.
Do
Spartite
Allen
Do You Yahoo!?
Agree that having the Haarstick staysail makes for better all around sailing experience. And I’ll take the 243 rating any day! This little boat could actually win a lot of Wed. night races here on LIS because she is so good in light air (which is frequently the case here on summer evenings). My question is: where is the best performance - is it when the staysail is all the way up to the sheave or when it is tight to the tack? How much tension can be put on the halyard to stiffen the luff (given there is no wire forestay to hank onto)?
Emmylou’s staysail has about 5" of line between her tack cringle and the shackle so the head runs right up to the mast. I’m thinking of getting rid of that line and replacing it with a shackle to the snap shackle. That should give a little more room at the head for tensioning. Also, has anyone used an inhauler to improve windward pointing? Seems like the thing to do unless one is going to go with tracks on the cabintop.
Sean - Emmylou 307
-----Original Message-----From: freedom21@yahoogroups.com On Behalf Of Allen McClungThank you, John. I’ll go to Haarstick and price the class staysail. — In freedom21@yahoogroups.com, John wrote:Allen, A jib (staysail) is available for the Freedom 21. Actually two. A “blade” and the “class”. See http://www.freedom21.info/f21sails.pdfI bought the “class” staysail for my 21 (“Blue Merle”) directly from Haarstick for about $500 (circa ~1996). See picture: http://www.freedom21.info/images/bluemerle/BMMainJib.jpg It is great in light air and for pointing. However, it needs to come down above 10 knots of wind as the boat will be overpowered. A worthwile investment. However, it does change your rating a bit. You are no longer a “cat” rig, but a “sloop”. See the example ratings from the PHRF NE site: FREEDOM 21 CAT 255FREEDOM 21 SLOOP 243FREEDOM 21 SLOOP SD 252 Regards,-JohnFormer “Blue Merle” owner (#259)
A few tidbits:
  1. The official class sail had a snap shackle at the tack that clipped
    to the hoop at the top of the spinnaker sleeve on the gun mount.
  2. Haarstick will not list Freedom 21 sails at their web site as the
    model is “out of date”. However, they do have all of the proper
    measurements as they built the original sails. In any event, the sail
    dimensions are at the Freedom 21 web site
    (http://www.freedom21.info/f21sails.pdf).
  3. As for tracks on the cabin top, it isn’t really necessary. You
    just need a sheet block. See the details of what I did.
    http://www.freedom21.info/jibsheetblocks.htm
    http://www.freedom21.info/images/bluemerle/BMJibSheetBlock-2.jpg
-John
— Sean Mulligan <quadmulligan@…> wrote:
MessageAgree that having the Haarstick staysail makes for better all
onto)?
Sean - Emmylou 307
Allen,
FREEDOM 21 CAT 255
Regards,
-John
Do You Yahoo!?
Ahhh…I see your cam cleat is inboard.
Emmylou has them on the outer edges of the cabin top.
If it comes down to racing your setup looks great.
Were you using the spin yard? Don’t see “reins.”
Sean
-----Original Message-----A few tidbits:1. The official class sail had a snap shackle at the tack that clippedto the hoop at the top of the spinnaker sleeve on the gun mount.2. Haarstick will not list Freedom 21 sails at their web site as themodel is “out of date”. However, they do have all of the propermeasurements as they built the original sails. In any event, the saildimensions are at the Freedom 21 web site(http://www.freedom21.info/f21sails.pdf).3. As for tracks on the cabin top, it isn’t really necessary. Youjust need a sheet block. See the details of what I did.http://www.freedom21.info/jibsheetblocks.htmhttp://www.freedom21.info/images/bluemerle/BMJibSheetBlock-2.jpg-John
Get amazing travel prices for air and hotel in one click on Yahoo! FareChase
Posted by pmonette@…> (pmonette@…>)
I ordered a jib two years ago from Haarstick and have been very happy with it.
They had all the measurments for it.
Paul M.
Fancy Free #128
Date: Tue May 09 13:15:11 CDT 2006
To: freedom21@yahoogroups.com
Subject: RE: [freedom21] Re: Jib
A few tidbits:
-John
onto)?
Sean - Emmylou 307
Allen,
FREEDOM 21 CAT 255
Regards,
-John
Do You Yahoo!?
 YAHOO! GROUPS LINKS
Visit your group “freedom21</a](http://groups.yahoo.com/group/freedom21">freedom21</a)>” on the web.
freedom21-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
