Having been up my mast a few times (including yesterday) with an
ATN top climber I thought I’d post some thoughts and tips.
With the ATN you can get above the masthead with your upper body
using the footstraps and this is quite helpful. Although you are secure in
order to work properly you need to use an arm to pull yourself forward against
the mast. This is tiring and means one handed work. A strap to put around
you and the mast while you work could be helpful.
2.
It says its helpful to secure the line at an angle to the mast.
My first time up I thought more would be better. This made it more
difficult on the arms always pulling my body towards the line. Subsequent
times I reduced the angle. The ideal seemed to be a foot or 2. I
have settled on tying it to a cleat on the boom (outhaul or lazy jack) and then
as down to a deck cleat (although this end of the line is not critical its just
to keep from swaying so you do need to at least make it tight).
3.
I now start by standing on the sail/boom in between the
lazyjacks and I am careful not to get tangled. Saves a few feet of climbing and
is a soft place to start or land and has plenty to hang on to.
4.
I use my spare halyard tied to a deck cleat near the mast and
use a separate cleat designed specifically as a safety. It has a short webbing
and shackle. I slide this up as I go. Just eliminates the chance that the main
halyard failure failing would cause a fall.
5.
I have short legs so it goes faster if I lean back to release
the leg cleat tension rather then just taking short steps. This is especially
helpful and easy going down.
The whole thing takes a little time to rig since all the cam cleats
are closed and you need to slide the ends of the lines through to start off and
if you forget one attachement or get them reversed you need to start over.
Overall I’m very happy with it as a way to get up alone. It
is some work but you can go as slow as you like and its very secure especially
with my setup with the separate halyard and cleat redundancy.
Alan F-33 SEAPR Hull #51.
Behalf Of rossbakery
Sent: Monday, September 22, 2008 5:03 AM
Subject: RE: [FreedomOwnersGroup] Re: Mast Climbing
Hi Marno,
Thanks for your experience. It’s scary stuff.
I’m in Tassie so won’t
be making the meet in Holland.
But I will be over in UK for a couple of weeks in October.
I don’t know where you are but just maybe we could fix
to meet up. I’ll be based in Sussex and I’d travel for a day or so
just to have a look at a 39.
If you think this is a possibility send me through your
contact details. My direct e-mail is chris@…
Cheers
Chris L-B
15 Church Street,
Ross,
Tasmania, 7209
Australia
tel 0061 (0)3 63 815246
fax 0061 (0)3 63815360
www.rossbakery.com.au
-----Original
Message-----
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com]
On Behalf Of marno_ss
Sent: Saturday, 20 September 2008 2:01 AM
Subject: [FreedomOwnersGroup] Re: Mast Climbing
I’m coming over tomorrow for the meet in Holland, if you would like I
can bring the top climber so you can try it if you like. Let me know.
Regards
Marno
— In FreedomOwnersGroup@yahoogroups.com,
“michel.capel”
<michel.capel@…> wrote:
Hi Chris,
I went up my 50’ mast singlehanded last month. I bought climbing gear
(two ascenders) and some carbiners and stuff. Took some effort, But I
got there. I used a slightly different line setup than the ATN
topclimber. I did not use a static line, but used the purchase of the
halyard. Then it takes half the power to lift my 100 kgs. The
topclimber is quite expensive if you already have a bosun’s chair. I
also use a chest harness (lifejacket) to sit more comfortable. On the
way down, my halyard got snagged under a deck cleat. My neighbour was
around, and he had to help me. This is something to watch out for and
speaks in favour of the static line method. Halfway up the mast I
suddenly got scared… I was only hanging from one shackle… I
swallowed and got up to the top without further thoughts because I
knew all masthead fittings had been renewed two years ago. But next
time, I’ll go up with somebody on deck below to handle a safety line.
